One can i-click anywhere in the SE, TO or GE, and then just press ctrl-space bar (or is it option-spacebar?). This can be done anywhere, even on top of any soundbite.zed wrote:I was talking about the ruler... but I have figured out what causes the difference...bayswater wrote:You're right, a single click does it. But I think what Zed is talking about is a single click anywhere in an edit window where there isn't some sort of event. It was present in Cubase, but had its drawbacks. I find using the keyboard short cuts for cursor movement covers most cases quicker.James Steele wrote: Really? You have to double click? I thought when you hover the cursor over the ruler the cursor will change and you locate there with a single click.
If you move the mouse cursor anywhere in between the actual NUMBERS on the ruler (i.e. at the same vertical level as the numbers) then all you have to do is single-click. If, however, you click on the actual edge of the ruler where the little vertical measurement indications are located, you can double-click to achieve the same effect (and that is how I have been doing it, unaware that I could save myself a click if I reached a few pixels higher).
And this is exactly the kind of precision I am asking MOTU to eliminate. There is no reason why you shouldn't be able to do this same function without having to reach up for the ruler.
I don't know about Cubase, but StudioVision Pro handled this very well and there was no reaching required.
That will start playback from where ever you i-clicked. Hitting ctrl-spacebar takes as long as just hitting spacebar.
