DP 7.2 is out ! !
Re: DP 7.2 is out ! !
Boom!
Loaded 7.2 today and have not been able to bring it up unless I skip loading Ethno.
This is on a Mac recently upgraded to 10.6.4. Just noticed that Ethno and SL have some issues...
No. I know it's on their list however.gongbass wrote:Does it include Out of the Box latency correction? Probably not, I'm hoping DP8 will... its my #1 request!
- KEVORKIAN
Yes!James Steele wrote:No. I know it's on their list however.gongbass wrote:Does it include Out of the Box latency correction? Probably not, I'm hoping DP8 will... its my #1 request!
- cbergm7210
Could you explain what that is, exactly? I am not familiar with that term.James Steele wrote:No. I know it's on their list however.gongbass wrote:Does it include Out of the Box latency correction? Probably not, I'm hoping DP8 will... its my #1 request!
http://www.rfjmusic.com
- cowtothesky
The new theme thing doesn't really excite me. I'm perfectly happy with the look of DP as it is. However, the right click menus looks like something that could be very helpful to me. I am reluctant to upgrade, because everything is working so well right now.
Question - I still have DP 7.1 in my applications list after updating to DP 7.12. Is it safe to drag my old app - 7.1 to the trash folder? I guess I'm concerned that the DP 7.12 only contains the updates and deleting 7.1 would mess up something. Thanks
Imac Pro 10-core, 64GB Ram, Mac OS (latest), 2TB SSD, Blackmagic Multiport 4TB SSD, DP 10, Motu Ultralite MK3 Hybrid, VSL Instruments, VE Pro, Vienna Suite, Spectrasonics, Project SAM, Spitfire, Kontakt, Korg M3
Each DP application contains all that it needs except for other files and preferences that it references. So if you just delete the application, you will not affect any other versions. If you haven't opened 7.1 in a while then it is safe to delete it.cowtothesky wrote:Question - I still have DP 7.1 in my applications list after updating to DP 7.12. Is it safe to drag my old app - 7.1 to the trash folder? I guess I'm concerned that the DP 7.12 only contains the updates and deleting 7.1 would mess up something. Thanks
That would place you solidly in the minority. Open up DP 7.2 and switch it to either Alloy or Producer, for example, and then get back to us.cowtothesky wrote:The new theme thing doesn't really excite me. I'm perfectly happy with the look of DP as it is.
- cowtothesky
Cool. Thanks.zed wrote:Each DP application contains all that it needs except for other files and preferences that it references. So if you just delete the application, you will not affect any other versions. If you haven't opened 7.1 in a while then it is safe to delete it.cowtothesky wrote:Question - I still have DP 7.1 in my applications list after updating to DP 7.12. Is it safe to drag my old app - 7.1 to the trash folder? I guess I'm concerned that the DP 7.12 only contains the updates and deleting 7.1 would mess up something. Thanks
- cowtothesky
James Steele wrote:That would place you solidly in the minority. Open up DP 7.2 and switch it to either Alloy or Producer, for example, and then get back to us.cowtothesky wrote:The new theme thing doesn't really excite me. I'm perfectly happy with the look of DP as it is.
I am still relatively new to DP - 6 month user. So, I love the way it looks as is. I prefer more of a professional look than just having something that looks cool. However, I will take your recommendations and give it a try as soon as I upgrade.
I opened up DP this morning and forgot that I was using a "theme" and I gasped in joy as the project unfolded. Inspiring. Grabbed a big cup of coffee and got to work!
Aesthetics matter.
Smart move, MOTU!!!
Does anyone know if the "theme" is saved with the song? I'm working on only one project right now, so I haven't tested it.
Wouldn't it be smart if the "theme" is saved with the song? That way, you could assign certain themes to certain musics with certain moods. That would be AMAZING if it worked that way.
- c
Aesthetics matter.
Smart move, MOTU!!!
- c
- KEVORKIAN
I agree completely. Aesthetics matter greatly to me. I don't believe that the MOTU allows you to save the theme with the song, however that is an excellent suggestion and could be done as a simple checkbox in the "Save As" dialog, I believe. You may want to suggest that to MOTU directly.beautypill wrote:I opened up DP this morning and forgot that I was using a "theme" and I gasped in joy as the project unfolded. Inspiring. Grabbed a big cup of coffee and got to work!
Aesthetics matter.
Smart move, MOTU!!!
- c
- toodamnhip
I wish many many settings were saved with a song or at least optioned to do so.
Swing %, repeat-type (paste, merge splice), and many other central settings should be fixable to the song.
Get a swing% quantize just right, leave the song, go to another, change the %, come back to the 1st song and it's gone unless you wrote it down in the comments section or saved it as a pre set
Set repeat to splice, go to another song, start repeating a drum part only to realize 10 min later that you have pushed the drums back in the 2nd chorus by 50 bars...lol...
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- toodamnhip
I am running DP 5.13 and I believe the MAS plug ins section has the MAS 5.13 drivers with the DP 7.01 plug versions. All has been working fine. I want to TEST the DP 7.2 upgrade and be able to go back to DP 5.13 should DP 7.01 and above still be uber-slow on my system. (It is a bug a I have never found and thus, i stayed at DP5).
Does anyone have any Comments on the odds of DP7.2's new MAS plugs screwing up my ability to work in DP 5.13 again?
I'd love to go to DP 7.2 "IF" it will not run slow.
Otherwise, I am waiting for the Mac Pros to completely upgrade evrything
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- KEVORKIAN
Rename your current MAS folder and call it "MAS DP5", Then install DP7. When you want to go back to DP5 just rename the current folder "MAS DP7" and delete the "DP5" from the original folder.toodamnhip wrote:I am running DP 5.13 and I believe the MAS plug ins section has the MAS 5.13 drivers with the DP 6 plug versions. All has been working fine. I want to TEST the DP 7 upgrade and be able to go back to DP 5.13 should DP 6 and above still be uber-slow on my system. (It is a bug a I have never found and thus, i stayed at DP5).
Does anyone have any Comments on the odds of DP7's new MAS plugs screwing up my ability to work in DP 5.13 again?
