Pirates and thieves SUCK! They are among the lowest form of scum on the earth. That is a fact.
We see them here at their anual [sc] meeting...
Err Normalize is already there, just not in real time, but off line.erikjamesmusic wrote:+1000 for "MIDI Learn" or "Assign MIDI Controller". This corresponds to a right-click menu, etc.
-tab to transient
-"normalize" audio effect
Huh? No.Timeline wrote:Anyone have a list of the shortcut commands? Steele?
Also. NO ILOK EVER!
Yes- that's a great idea!! Plus, how about a paragragh in the manual on Buffy and what it does. Last I checked it's the plug-in without any info!Phil O wrote: My suggestion for next DP: Easy way to calibrate/compensate outboard gear latency.
On of my hopes is for an External Instrument plugin (with automatic delay compensation) that can be used with Rewire instruments as well as External hardware via inputs/outputs. Many other DAWs have such a plugin at this point and a similar one for DP would be very welcome!frankymax wrote:Yes- that's a great idea!! Plus, how about a paragragh in the manual on Buffy and what it does. Last I checked it's the plug-in without any info!Phil O wrote: My suggestion for next DP: Easy way to calibrate/compensate outboard gear latency.
From and old thread:frankymax wrote:Plus, how about a paragragh in the manual on Buffy and what it does. Last I checked it's the plug-in without any info!
Phil O wrote:OK. So let me tell you about Buffy. Way back in the olden days there was this device called the ADAT. DP touted sample accurate ADAT transfers with the MOTU 828 (the 828 has an ADAT sync connector). I was finding that from time to time the transfers were off a bit. Well, not quite a bit. No, more like off by exactly the number of samples as the buffer setting. I called Motu Tech support. At the time there was this jerk working there that didn't know jack (luckily he's gone now). Anyway, I called tech support at Sweetwater where I bought the 828. They put me in touch with an engineer at MOTU who actually listened to me. Much time was spent experimenting and reporting the results. Well, to make a long story short, the next update to DP included a plug-in called Buffy. Yep, you have me to thank for that one.mhschmieder wrote:Maybe this feature can join the ranks of the similarly-undocumented "Buffy" plug-in.![]()
Yeah, the paragraph could start out, "So, there once was this jerk in tech support."frankymax wrote:Thanks for that info Phil- now if MOTU can just incorporate that into the manual!
Phil O wrote:Yeah, the paragraph could start out, "So, there once was this jerk in tech support."![]()
I would like to have a View Clipping Contents command too. There are so many things MOTU could do to overhaul these little DP wonders which are fantastic!Frodo wrote: 1. One knows the specific track type and specific track order. I have to write this stuff down by hand or take a screen shot so that I can create a folder with the right track types in the right order, then move the individual tracks into place within the new project one track at a time. Once done, I then delete the original "temporary" tracks.
2. One creates individual clippings for each track and imports them individually.
Chunks? Similar issue on this end.
