Monitoring DP through cuemix
sbrewster_jones
Post by sbrewster_jones »
I am recording my band using ultralite mk3, cuemix and dp5.13.
I have created 4 separate mix busses in cuemix for the individual musicians.
My question is in regards to playback from DP.
I have been setting the output of each track to a stereo bus (eg bus1-2) then setting up 4 aux tracks with the inputs set to bus 1-2 and the outputs set to the appropriate output on the ultralite.
Obviously this means that I am bypassing the master fader in DP.
Is there a better way of doing this?
Is there a way of using the master fader to control the overall level that all musicians will hear?
Any help would be greatly appreciated.
Cheers,
Sam
magicd
Re: Monitoring DP through cuemix
Post by magicd »
Set up the DP playback mix like this:
Audio tracks>Bus 1-2
Bus 1-2>Aux Track A
Aux Track A>Bus 3-4
Bus 3-4>Aux Track B>Out 1-2
Bus 3-4>Aux Track C>Out 3-4
Bus 3-4>Aux Track D>Out 5-6
Bus 3-4>Aux Track E>Out 7-8
Aux Track A is the group master
The other aux tracks are individual out sub-masters.
Dave
sbrewster_jones
Awesome, thanks Dave!
Pappy725
Post by Pappy725 »
Does this give everyone the same mix of recorded tracks? for overdubs? Just trying to get my head around this one. Not enough coffee this morning. Yet.
Pap
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
wylie1
Post by wylie1 »
I never would have figured that one out.
Thanx Dave
Tim
Post by Tim »
Pappy725 wrote:Does this give everyone the same mix of recorded tracks?
Yes, for already recorded tracks, same mix, with just separate level control at the computer for each. They're each getting their own separate mix of the live inputs via the Cuemix console.
Pappy725
Post by Pappy725 »
Thanks, Tim. That's what I thought. Like I said, not enough coffee that morning.
Pappy
