Monitoring DP through cuemix
I am recording my band using ultralite mk3, cuemix and dp5.13.
I have created 4 separate mix busses in cuemix for the individual musicians.
My question is in regards to playback from DP.
I have been setting the output of each track to a stereo bus (eg bus1-2) then setting up 4 aux tracks with the inputs set to bus 1-2 and the outputs set to the appropriate output on the ultralite.
Obviously this means that I am bypassing the master fader in DP.
Is there a better way of doing this?
Is there a way of using the master fader to control the overall level that all musicians will hear?
Any help would be greatly appreciated.
Cheers,
Sam
Cheers,
Sam
Re: Monitoring DP through cuemix
Set up the DP playback mix like this:
Audio tracks>Bus 1-2
Bus 1-2>Aux Track A
Aux Track A>Bus 3-4
Bus 3-4>Aux Track B>Out 1-2
Bus 3-4>Aux Track C>Out 3-4
Bus 3-4>Aux Track D>Out 5-6
Bus 3-4>Aux Track E>Out 7-8
Aux Track A is the group master
The other aux tracks are individual out sub-masters.
Dave
Bus 1-2>Aux Track A
Aux Track A>Bus 3-4
Dave
Awesome, thanks Dave!
- Pappy725
Does this give everyone the same mix of recorded tracks? for overdubs? Just trying to get my head around this one. Not enough coffee this morning. Yet.
Pap
Pap
I never would have figured that one out.
Thanx Dave
Thanx Dave
Yes, for already recorded tracks, same mix, with just separate level control at the computer for each. They're each getting their own separate mix of the live inputs via the Cuemix console.Pappy725 wrote:Does this give everyone the same mix of recorded tracks?
- Pappy725
Thanks, Tim. That's what I thought. Like I said, not enough coffee that morning.
Pappy
Pappy
