I just discovered "Drive Genius" by Prosoft Engineering and would like any feedback on it from anyone using it. Especially in comparison to T.T.P, iDefrag, etc.
http://www.prosofteng.com/products/drive_genius_info.php
Are you using it?Originally posted by inukshuk:
Hi all
I've been using Alsoft products for years and have found the programmes reliable and lifesavers. DiskWarrior used to be their DiskExpress albeit it was also like TechToolPro.Yes I have all of them and use them all. But I use mostly T.T.Pro 404. Disk Warrior only if TTP can't do the job, starting to use Genious and use iDefrag once in a while. And between Cocktail and Oynx, well Oynx has more options. But if you were to buy 1-2 I would say TTPro and Oynx. They all seem good but work a little differantly. The one that takes a very long time to do the job is iDefrag. The others are all much faster.
I've just acquired a copy and their other programmes and going thru the paces with them.Originally posted by inukshuk:
Hi all
