Suggestions for next DP update
chaim
Post by chaim »
• What's possible with Option A (audio assignments) regarding audio tracks, should be possible for MIDI tracks and sends as well.
• my long time request, a solo button in the SE, by each track.
Mac Pro 2X quad core 2.26 Ghz, 22 GB RAM, OS 10.8.4 | DP 8.05 | 2408MKII
Beta Tester for Toontrack
Tesionman
Re: Suggestions for next DP update
Post by Tesionman »
chaim wrote: • my long time request, a solo button in the SE, by each track.
Agreed!
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
grouse
Post by grouse »
Agreed!
Agreed +1.
DP 7.24, Focusrite 18i20, 3.06GHz Intel Core i3, OSX 10.9.5, 4 GB RAM, Reason 10, Kontakt, Motif +++
kassonica
Post by kassonica »
Tab to transient has been on the top of my list for a long time.
Post by Shooshie »
Comping MIDI tracks would be nice. Especially if it were "smart" so as to finish open-ended controllers if other controller of the same type do not follow. (Sustain pedals, for instance.)
chaim
Post by chaim »
• mute MIDI notes
• a quicker way to pencil in, different CCs one after the other.
(like if you pencil in a MIDI track an adjustment on expression, then you want a little adjustment on the modulation etc... it becomes sort of a pain to have go through the mebus and select.) If you need to do this very often, you'll perfectly understand my point. 8)
Tesionman
Post by Tesionman »
ohhh hell yesss! Definitely Tab to transient and Muting MIDI notes(individual notes in MidiEd and whole blocks in TrackOv)!
newrigel
Post by newrigel »
Just highlight and delete... then ⌘Z he he. There's your MIDI note mute.
shaman
Post by shaman »
It would be useful these features:
- Go To Next/Previous frame.
- Set Region Start/Sync Point/End to playhead.
- Play movie in fullscreen on secondary monitor.
- Movie follow nudge edition.
OS Mavericks (10.9.5)
Protools HD Native 11. Logic Pro 9. Digital Performer 8.
Waves 9 Mercury Bundle. iZotope RX 3 Advanced.
Avid HD OMNI. Apogee Ensemble.
daniel.sneed
Post by daniel.sneed »
A preference choice between different pan laws :
center -3 dB (I won't have any use of this one, I guess)
center -4.5 (actual DP pan law, AFAICR)
center -6 dB (this one would fit most of my projects)
BTW, I've already sent this suggestion to Motu.
FMiguelez
Post by FMiguelez »
chaim wrote:• mute MIDI notes
If you click on any controller point in the SE, you will instantly be able to edit it.
Especially nice if you are working in Lines mode.
ccrane
Post by ccrane »
Such a simple, tremendously useful function.
God bless 'em, but I just don't think MOTU gets it - I mean, 7 versions in and no solo in SE? :shock:
No... obviously they're totally and utterly clueless.
cbergm7210
Post by cbergm7210 »
+ Me
http://www.rfjmusic.com
As an alternative option, I'm pretty sure you can use a keyboard shortcut to engage Solo Mode, and then you can click the play enable buttons to designate which tracks are soloed or even option click the play button of one particular track to solo just that track.
