Hi,
I'm trying to hook up my condenser mic to the mic/instr inputs at the front of the 828-mk3. I'm using a TRS to XLR connector from the MOTU to the mic. The 48V is switched on. When I probe the pins, I do not get any voltage across the pins. The microphone works with my other equipment.
Is there some software or other setting I need to enable in order to use the phantom power? Is the mic input broken?
Thanks.
828-mk3 Phantom Power not working
Re: 828-mk3 Phantom Power not working
Nevermind, you have to connect with an XLR in order to use the Phantom Power at the MOTU.
