sorry for taking so long in getting back - been busy getting new studio soundproofed!Frodo wrote:I just tried this with some audio starting at measure 1. For the sake of this thread, I added 4 measures at the beginning of the sequence--- measures, -3, -2, -1, -0.doodles wrote:yep. chunks/sequence start. Just reset it to start at bar 0/1/whatever
I set the Chunk start time to measure 1-- the negative measure numbers are gone, but the audio now starts at measure 4. I get the same result whether or not I "preserve current time frame" or "preserve length of time from start of chunk". What really troubles me is why the audio doesn't start at measure 5 if it has to start anywhere except for measure 1, but that's a whole 'nother topic.
Yeah, I know-- select all and left arrow everything into place, but what did I miss? After resetting Chunk start, there are still empty measures at the top to deal with. Will try this out again on a different computer in a little bit.
I've often wondered why-- if there is an Insert Measures feature in the Modify Conductor Track dialog-- why there isn't a Delete Measures feature as well.
Thoughts?
Not sure I understand? So I've just gone and put, as an example, 4 measures in the set chunks start time, and now the sequence starts at bar 4 (with the same timecode as bar 1 was now being at bar 4). The only thing that seems a bit weird is that I can't physically see bars 1 to 4. It's like having a 3 bar count in, and then the cursor starts moving when the counter gets to bar 4.
Is this what you're talking about? In which case, agreed it's a bit weird. I would have thought the whole point of this feature would be, to give an example:
Scoring a q for a film. Suddenly want to add a bit before-hand, so add 2 bars extra at the top. This would be super-simple. But instead, I would have to work out the time difference manually and then alter the chunk start time accordingly.
Actually, thinking about, what the heck is the point of this function then?
