mic and pre
- Henry Robinett
Re: mic and pre
You need a hardware compressor for tracking. Signal goes in to DP analog --> mic -> pre -> compressor ->A/D converter -> DP. I've never known a plug for a native system to be able to effect the signal before it hits the converter. I might be wrong. I've never done it. With a compressor this is what you want, primarily. You want to limit/color/compresses the signal BEFORE conversion.
All the best,
Henry Robinett
2019 Mac Pro 16 core, 192 GB; 2 MacPro 5,1 Metric Halo ULN-8 3d (x6), ULN-2-3d, MIDI Express XT,
DP10.13, UAD2 Quad TB,Duo,solo, Fractal Ax Fx III, FM3, LF+12+, Altiverb 7, Pianoteq7, Falcon, Keyscape, Omnisphere, Kontakt 5, Superior Drummer 3, Slate Drums, Live 10, Battery4, Diva, Spitfire Chamber and Symphony Strings, Ivory 2, Spectrafoo, Millennia HV3-D, many mics, many guitars . . ..
Henry Robinett
Re: mic and pre
I never tried yet... but I remember something into the UAD-1 manual where it says something about use of the plugins tracking.
I'll check it out, and I'll try when I get a pre
Thank you for everything
alix
alix
alix
- sdemott
Re: mic and pre
No I mean the 312 (though the 512 is cool too). Check out Mercenary Audio they have the API 3124+ (4 channels of 312 pres in a 1 space rack).Originally posted by soof:
Sdemott: do you mean API 512? Didn't find a 312 anywhere![]()
What I like about the 312 is that you can get a lot of texture out of it, as well as just a god amount of smoothness when you don't want a lot of the color.
-Steve
Not all who wander are lost.
Re: mic and pre
Hi HenryYou need a hardware compressor for tracking.
I tried with a UAD compressor and it works: just needed settings the MOTU buffer size at 64 to minimize latency.
The UA manual says that UAD latency is doubling the buffer value.
alix
alix
Re: mic and pre
I've had a look to the API 3124: unfortunately it's out of budget.No I mean the 312 (though the 512 is cool too). Check out Mercenary Audio they have the API 3124+ (4 channels of 312 pres in a 1 space rack).
Tnx anyway
I'll try to find here a 512 to test with the GEFELL mic.
I've found a MILLENNIA TD-1 at a reasonable price, and at present seems to be the best choice in my list
alix
alix
- Henry Robinett
Re: mic and pre
Great!! You won't be sorry. Also good news about the UAD being able to use it to RECORD in addition to mix. I learn something new every day!Originally posted by soof:
alix
All the best,
Henry Robinett
Henry Robinett
Re: mic and pre
The TD-1 is great. I found it was not only good with a ribbon mic [R84] but was amazing as a direct for P Bass direct into
Dual 2G-G5/2G ram/Digidesign HD2 Accel/Sony DMX R-100/MeyerHD-1&NS-10s - Hafler Ars Nova/DP5.12/PT7.3.1/2.0+TByte/GigaS3
Re: mic and pre
True Systems are distributed in North America by Neuman.Originally posted by soof:
Inukshuk: TRUE SYS P2 analog's got the same quality? I don't know if it's distributed in Italy: I'd really like to test it before I make up mind 'bout what to buy.
I don't need all 8 ins of the one you told me, for me a dual/stereo pre is more than enough![]()
Thanks a lot to all of you[/QB]
Dual G4, 1.42GHZ, 2,048 ram, 3-74gb Raptors, 1-250gb Caviar, OS X Tiger 10.4.5, D.P. 4.61, HUI, Tannoy 600a's, UAD-1,Fairchild, Pultec-Pro, tc PowerCore firewire, Restoration Suite, MD3, VSS3, Inflator, Voice Modeler, Assimilator, Auto-Tune4, PowerCouple, PSP MasterQ, Vintage Warmer, MixPack, Blue Tubes Bundle, BFD, motu 896 HD.
http://www.inukshukproductions.ca/mastering
Re: mic and pre
TRUE SYS is not imported here in ITALY :-/
What do you think about LANGEVIN DualVocalCombo and Manley MonoMicPre?
Thans a lot again
Thans a lot again
alix
Re: mic and pre
Last year, I posted the same question because I had some dough to blow and wanted to invest in a real nice preamp. Many of the folks on here gave me some good recommendations. I ended up going with the Summit MPC100A. I ended up liking it so much that I bought a 2nd one so I could do stereo overheads on drums. For my vocals, this preamp really made the difference that I was looking for, however, I would say that it isn't the optimal choice for clean, pristine reproduction. If you're looking for that fat, warm vintage sound, then the Summit is a good choice.
Macbook Pro, DP11, Motu M4, Waves, PSP
Re: mic and pre
Thanks Shanky
I'm gonna have a look to Summit stuffs too
I see that you own a 828mkII
Do you know what the best way to chain it with a FW hard disk?
Which one before to get the best results with a Mac carryin' just 1 FW socket?
alix
alix
alix
Re: mic and pre
Soof, if you decide on a Summit, check Ebay and see if there are any there. I got both of mine on there. (one for $1,100 and the other for $950)
As for the 828 question, unfortunately, I don't have an answer for you because I have always used the harddrive in my laptop. The only time I use an external drive is for back up or file transfer. My guess would be that you would want the 828 before the FW drive.
Re: mic and pre
Tnx, but Summit seems to not give a good result with my Gefell Mic.
I'm actually more oriented on different stuffs, such as MILLENNIA TD-1, GREAT RIVER ME-1NV , and Focusrite ISA mkII, and others such as GROOVE tubes VIPER that I hope I'll have a chance to test in the next days, 'cause I'm in a hurry to buy my Mic Pre for using in the starting production.
Tnx anyway
alix
Tnx anyway
alix
alix
- Tritonemusic
Re: mic and pre
Hi Henry,Originally posted by Henry Robinett:
I haven't used the VW much lately. But it is fine. I haven't upgraded it to OSX.
If you don't already know, the OS X version of Vintage Warmer is a free upgrade for registered owners of the OS 9 version.
<small>[ March 13, 2005, 02:03 AM: Message edited by: 666 ]</small>
