UltraLite MK3 Glowing Blank!
eatsoap
Post by eatsoap »
Hi,
My ULmk3 was working fine when it suddenly turned off.
When I turned it back on the LSD opened with "MOTU" on the screen then went blank while still glowing and unresponsive to any buttons or knobs. I haven't been able to use it since. I've tried numerous times to turn it back on and all it does is glow the LSD blank until I turn it off again. has this happened to anyone?
Open to any suggestion!
david47
Re: UltraLite MK3 Glowing Blank!
Post by david47 »
The same thing happened to me , mk3 hybrid , I was running firewire with the ac adapter , I shut everything down , and , disconnected the ac adapter and ran the firewire ( that sends power to the unit) , it stopped...
eatsoap
Post by eatsoap »
...are you saying this fixed the problem? if so I've tried that and my Ultralite remains blank :cry:
david47
Post by david47 »
Yes , and it has not happened since then , either that was the remedy , or it was just a glitch / power surge ?
Manachi
Post by Manachi »
eatsoap i'm experiencing the same thing. did you end up resolving this problem? what was the outcome? anyone know?
