Good to know it's not a bug. Interestingly, I only have 1 MIDI track in this sequence but the project file was generated last week on 7.02 so it sounds like a fresh project file should clear it up for me.I have had a few experiences in the past where some CC's would be reseting every time I hit play. Usually it was due to another track earlier in a large session that had written CC for the same channel. With event chasing on, DP will see the last CC setting for a given channel and then jump to that setting even if you are on a new a new track. Also, you might have a corrupted session. If all else fails, I would try loading into a new session.
Thanks.
