Fixed/Not fixed/Broken in DP 7.1
Phil O
Post by Phil O »
Thought I'd start a thread where we could list things that we have found to be fixed, not yet fixed, or broken in this version.
[not yet fixed] So far I've run across the "sleepy fader syndrome" in 7.1
and
[fixed] It seems the problem of preferences not remembering file formats has been fixed. I don't know if that was a 7 fix or a 7.1 fix as I went directly from 6.03 to 7.1. But so far all my new projects have come up with the appropriate file format. Been working with 7.1 all day. :D
Please add your findings.
Phil
Phil O
Re: Fixed/Not fixed/Broken in DP 7.1
Post by Phil O »
The new marker counter is not working at my end.
"The Markers counter can also be used to locate to a marker.
Click on the marker name to pop-edit the field and display a
drop-down menu, then choose a marker by clicking on it or
pressing Return or Enter to choose the highlighted marker."
If I click on the marker name I get MacOS error: Unexpected error (-8796). Can anyone confirm this?
Phil
mrgkeys
Post by mrgkeys »
per an email from Magic Dave, Beat Detection now works properly on 96k files. And works like a charm it does indeed!!! Bad drummers of the world thank you.....
sadly though, I had 2 crashes in 7.1 last night, so I'm back to 7.02 which I have not had a single crash in, all the way back to 7.0. Sending logs to MOTU today, but they all start like this.. QD, is that Quickdraw?
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000001a
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.apple.QD 0x9740382c SetPortRGBForeColor + 53
1 com.apple.QD 0x9740586c RGBForeColor + 49
Pappy725
Post by Pappy725 »
I didn't crash after installing 7.1, but I did get the SBBOD twice after opening the last project I worked on. Restarted and get the folder with the question mark. Slipped in the SL disc and did the repairs thing. 7.1 still giving me the beach ball. Uninstalled and reinstalled and all seems fine now.
It was a little wonky, but I'm looking forward to trying it out. Couple of new projects on the horizon, why not go for it? :shock:
Pappy
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
mikeka
Post by mikeka »
Phil O wrote:The new marker counter is not working at my end.
Phil
Working fine here Phil with 7.1 whether stopped or in playback.
DP 8.07 64 bit, OS 10.10.5, Mac Pro 5,1 12-core 3.33ghz, 16GB ram, lots 'o plugs and VIs
apanacci
Post by apanacci »
Hey guys can you expand the transport on this version?
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
YRH
Post by YRH »
Well, maybe not a bug, but I notice something different between audio recorded in DP 7.02 and 7.1:
When recording a track In 7.02, as soon as I stop it, the recently created soundbite appears ready to be heard and edited (almost inmediately)
When I do the same in 7.1, the created soundbite takes a while to be ready, as if DP needs more time to "compute" it.
Its not really important, but there is a clear difference. Did anybody notice the same?
Cheers
Yuri A. Robles
www.ohmioaudio.com
waterstrum
Post by waterstrum »
Not Fixed....
Waves Vocal Rider plugin now works in write mode for a few seconds and then the beachball spins.
Bummer.
All is well
dix
Post by dix »
YRH wrote: When recording a track In 7.02, as soon as I stop it, the recently created soundbite appears ready to be heard and edited (almost inmediately)
Yes, I noticed this too.
dix
Post by dix »
Stylus RMX still locks out DP's transport. Very annoying.
Mark Walmsley
Post by Mark Walmsley »
Not sure if it's just me?
My usual way of making a selection in the tracks window is not working...
In previous version I'd select a few bars at the top of the tracks window then click once on one of the tracks from my long list to isolate something eg 2 bars of snare
Then command R to repeat a bunch of bars.
In 7.1 all seems ok until I get to the Command R and it remains greyed out.
I know there are other ways to select but this is habitual for me!
Is there a preference that relates to this?
Mac-Pro 8 core 2010, OSX 10.9.5, Motu DP 8.07, Apollo firwire, TC Powercore Firewire. User since Performer on Macplus in 1988
Phil O
Post by Phil O »
Phil
Found it. It was a font problem. The font "Verdana" must be installed. It was turned off in Font Book. Thanks, Mike.
Phil
Twitch_12
Post by Twitch_12 »
Yeah, I noticed this too. It's not just the repeat command, it seems that most / all commands requiring a time range selection in TO are greyed out unless you have all tracks selected. (Using the time ruler to select and not modifying your selection by clicking on track names)
The work around I found was to switch to SE, it seems the problem doesn't occur in SE.
DP7.24, DP 8, MBP 8 core 2.3Ghz i7, 8GB Ram, 750GB 7200RPM Internal SSD Hybrid, OS 10.6.8. MOTU Ultralite FW 1.15 / Driver 1.6.54199
Twitch_12
Post by Twitch_12 »
Is it me or is DP 7.1 not chasing MIDI CC's?
I'm working on a cue, and I have CC #83 setup to control send level in Kontakt. Usually, I just twiddle a knob on my control surface and leave it at that.
DP 7.1 seems to be reseting all CC's when playback starts, which means I have to record the CC to the track. But it won't chase it. Kontakt only receives the CC when DP plays it.
Anyone else experiencing odd chasing behaviour?
tripit@earthlink.net
Post by tripit@earthlink.net »
Twitch_12 wrote:Is it me or is DP 7.1 not chasing MIDI CC's?
Nope, works fine here...and I just used CC#83 in a track. As for chasing, do you have event chasing turned on? Not clear on your problem, Kontakt only receives CC when DP plays? That would be event chasing. Your controller doesn't send CC?
I have had a few experiences in the past where some CC's would be reseting every time I hit play. Usually it was due to another track earlier in a large session that had written CC for the same channel. With event chasing on, DP will see the last CC setting for a given channel and then jump to that setting even if you are on a new a new track. Also, you might have a corrupted session. If all else fails, I would try loading into a new session.
Last edited by tripit@earthlink.net on Thu Jan 21, 2010 4:55 pm, edited 1 time in total.
