Dp MIDI overloud caused by roland Vdrum
tobysan
Post by tobysan »
Hello friends.. i appreciate any help... thanks in advance.
I have this MIDI problem, when i play any pad on a Roland Vdrum, thats overload DP
its like a punch all the pads at the same time.. and thats sound like all the notes was play it..
i record it and its look like this:
thanks !!
Mac pro 8 Core 2.8GHz, 10G RAM, OSX 10.5.6, DP 6.02
PCI 424 e, 2408mk3, MTPAV,rosetta 800, BigBen WC
Latin Music production and songwriting..
www.myspace.com/tobysandoval
Re: Dp MIDI overloud caused by roland Vdrum
Take a look at the V-Drum MIDI settings. You may have MIDI Merge enabled, which could cause a MIDI feedback loop....
tobysan
Post by tobysan »
Thank you HCMarkus !
I cant find "MIDI merge" on TD10 global functions, the only MIDI function i found is:
local control/ off
softthru/on
notechase/on
pedal data thin/off
do you know where i can find "MIDI merge" ?
thank you very much for your help...
Tim
Post by Tim »
What does Soft Thru do, and does it need to be on?
What if you try it with TD10 local on, and MIDI patch through turned off in DP?
Tim wrote:What does Soft Thru do, and does it need to be on?
+1
tobysan
Post by tobysan »
thank you friends,
work, no more MIDI overload, but i can't received MIDI notes,
if i change patch number on DP it change the patch on Td10
but if i hit the pads i can listen the drum but it doesn't record MIDI on DP..
tobysan
Re: Dp MIDI overloud caused by roland Vdrum(resolved)
Post by tobysan »
Yeeeah... it work !!
thank you friends !
local on and MIDI patch thru off solved the problem !!
also i had multirecord on, that was part of the problem also..
Post by Shooshie »
tobysan wrote:Yeeeah... it work !!
thank you friends !
I would guess that multi-record was the entire problem. You can surely use MIDI patch thru, can't you?
I'm guessing "Soft Thru" on the Roland (which could be another way to say "MIDI Merge") is the real issue.
Tim
Post by Tim »
HCMarkus wrote:I'm guessing "Soft Thru" on the Roland (which could be another way to say "MIDI Merge") is the real issue.
Yeah.
I suggested turning patch thru off in DP in order to sus out the problem, though it can be used as a work around. More convenient though would be to shut it off in the TD10.
Did you try shutting off SoftThru first, TobySan?
