Hello friends.. i appreciate any help... thanks in advance.
I have this MIDI problem, when i play any pad on a Roland Vdrum, thats overload DP
its like a punch all the pads at the same time.. and thats sound like all the notes was play it..
i record it and its look like this:
thanks !!
Mac pro 8 Core 2.8GHz, 10G RAM, OSX 10.5.6, DP 6.02
PCI 424 e, 2408mk3, MTPAV,rosetta 800, BigBen WC
Latin Music production and songwriting.. www.myspace.com/tobysandoval
I cant find "MIDI merge" on TD10 global functions, the only MIDI function i found is:
local control/ off
softthru/on
notechase/on
pedal data thin/off
do you know where i can find "MIDI merge" ?
thank you very much for your help...
work, no more MIDI overload, but i can't received MIDI notes,
if i change patch number on DP it change the patch on Td10
but if i hit the pads i can listen the drum but it doesn't record MIDI on DP..
Yeeeah... it work !!
thank you friends !
local on and MIDI patch thru off solved the problem !!
also i had multirecord on, that was part of the problem also..
tobysan wrote:Yeeeah... it work !!
thank you friends !
I would guess that multi-record was the entire problem. You can surely use MIDI patch thru, can't you?
|l|OS X 10.12.6 |l| DP 10.0|l|2.4 GHz 12-Core MacPro Mid-2012|l|40GB RAM|l|Mach5.3|l|Waves 9.x|l|Altiverb|l|Ivory 2 New York Steinway |l|Wallander WIVI 2.30 Winds, Brass, Saxes|l|Garritan Aria|l|VSL 5.3.1 and VSL Pro 2.3.1 |l|Yamaha WX-5 MIDI Wind Controller|l|Roland FC-300|l|
HCMarkus wrote:I'm guessing "Soft Thru" on the Roland (which could be another way to say "MIDI Merge") is the real issue.
Yeah.
I suggested turning patch thru off in DP in order to sus out the problem, though it can be used as a work around. More convenient though would be to shut it off in the TD10.
