Hint: MOTU, it would be nice if you could make a downloadable PDF of the English user manual for those of us who can't access the printed version.
First, does anybody know the specs of the headphone amp? I'm going to be using it with my Grado RS1i's.
Second, what amount in output level change does each click of the front pannel volume knob represent? I'm guessing it's less than 1dB, since it takes several clicks for me to start noticing the volume change.
Also, is there anything I should worry about when interfacing the main XLR outs with consumer gear that normally accepts -10dB on unbalanced RCA's? I have the correct XLR-RCA cables, but I'm wondering where to set the output trim to get correct levels.
Thanks for any help,
Chris
