Having "fits" with Euphonix McMix
whoshivsagit
Post by whoshivsagit »
Have sent one unit back (pan not working), now replacement unit
is bad on so many levels.
1. LCD not returning to instrument (stays on pan)
2. "Groups" don't function correctly
3. "Shift Home" does not return to "home"
4. Several faders (on monitor)shake.
I hate to have to return this unless anyone has any suggestions that will
save "it". Next step....just return back to "working in the box"
I am using DP7.01 with a Mac Pro
rm/Austin
Since 1976 "Have Voice Will Babble"
stephentayler
Re: Having "fits" with Euphonix McMix
Post by stephentayler »
It would help if you say what programs you are using it with, which version of the Eucontrol software/firmware, OS etc....
Mine has worked flawlessly for 18 months on several different Macs and OS, in Protools HD and LE, Final Cut Pro, DP, CueMix etc.....
It sometimes needs a little troubleshooting and reinstalling, but I haven't had the problems you mention.
Kind regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
whoshivsagit
Thanks,
rm/Austin
Stephen asked what version of firmware, software etc. of the Euphonix unit... NOT your version of Digital Performer.
...which version of the Eucontrol software/firmware, OS etc....
Slow down and answer the actual questions and someone may be able to help.
charlesparente
Post by charlesparente »
This may be obvious, but make sure that you have the most recent EuControl software AND firmware update for the McMix.
The firmware is updated from a menu inside the Euphonix software.
Firmware updates are not listed separately on the Euphonix website, so you need to manually check for a firmware update every time you update the EuControl software.
EuControl is not yet officially compatible with SL.
Using the current software in SL is iffy for many users.
About a month ago Euphonix said a SL update was imminent, but we're still waiting.
best,
Charles
Charles
http://www.dptips.net [...my very humble tribute to DP]
DP 8-latest version, Mac OS 10.9.4, MacMini 2012, 16GB RAM, Metric Halo ULN-2d, MOTU Micro-Lite usb MIDI interface, Vienna SE, VE Pro, Kontakt latest version, many Kontakt VIs and libraries.
whoshivsagit
Eu software 2.03.63120
Mac Pro 10.4.11
I also get several "jittery" fader movements on my monitor.
This is somewhat un-nerving. The values are minute....but still jumping up and down.
When I have made some "Groups", only one of the 2 faders respond
on the Mc Mix. i.e. say 2 tracks of acoustic guitar is grouped...
only one of the two faders will move both.
Isn't technology amazing....:-)
Thanks!!!
rm/Austin
