DP7, SL & Play Is it working?
b2
Post by b2 »
With DP7 and SL Play will crash DP7 when I try to load it. Does anyone have it working? I tried to re-install Play 1.2.5 and I get an error message.
Any ideas?
dinobass
Re: DP7, SL & Play Is it working?
Post by dinobass »
It's working here. I have a couple of issues, none related to end performance: most times the notes I play on my controller no longer are reflected on Play's keyboard (though the MIDI still works); and the output meter on the plug-in sometimes stops functioning (but the audio is always still output).
Mac Studio M2 Ultra 128G RAM OSX 14.3, 16" MacBook Pro M1 Max, UA Apollo x6, UA Apollo Twin, UAD-2 Satellite (x2)
daveyboy
Post by daveyboy »
Working here but just installed today and haven't taxed it yet. Also, the stuff I was working on was ancient mixes for a re-release so one song dated back 10 years. On another oldie I replaced some of the old MIDI strings with some PLAY instruments and it worked no problem.
Dave
www.dbwproductions.com
b2
Post by b2 »
hmm okay thanks for your input... somehow I managed to get it to work by instantiating Play first before K3 or VEPro. Before doing that it would just crash DP7... go figure.
Frodo
Post by Frodo »
b2 wrote:hmm okay thanks for your input... somehow I managed to get it to work by instantiating Play first before K3 or VEPro. Before doing that it would just crash DP7... go figure.
Well, VE Pro and PLAY both have their own "servers" which access RAM outside of DP. It's good to know instantiating PLAY first works best.
Should you ever upgrade to Kontakt 3.5 or 4.x, be aware that it also has its own independent server that runs outside of the DAW host. That would be a lot of competition for whatever RAM you have above the first 4GB.
celestial
Post by celestial »
There is definitely an issue with Play in DP7 with SL. It doesn't crash all the time, but a lot. And the log points to Play issues. Kernel Failure - bad access or something that I don't understand...
Macbook Pro, DP11.1
