Velociraptor fitting into 2.8 intel?
- daveyboy
In doing a search I read that the 300 gb raptor didn't fit into Sushsi's mac Anyone using these inside a machine like mine and if so did it slide without issue? Do u notice a speed boost with audio?
Dave
www.dbwproductions.com
Re: Velociraptor fitting into 2.8 intel?
They work fine, particularly as boot drives. The one with the "H" in the model number is back plane compatible, the one with the "G" is not.
Octo 2.8/10.6.4/DP7.21/PCI Driver 1.5.38352/BLA HD192s/UAD-1e & 5.50 plugs/Waves v7/Current/PSP/Altiverb6.3.5/Breverb1.5.8/Stillwell/Fabfilter/elysia/Brainworx
- daveyboy
What's "back plane compatible" mean? Did you have to physically modify the drive to get it into a drive bay?mesaken wrote:They work fine, particularly as boot drives. The one with the "H" in the model number is back plane compatible, the one with the "G" is not.
Dave
It means it will slip right in your computer which is the same one I have. Its where the the power and data connectors are mounted on the drive.
The "G" model has its connectors in a slightly different location than the "H" and won't slip in the Mac Pro 2008 and others that use back plane
compatible mounts..
compatible mounts..
