New drivers available: 3.6.8.1414
TRANTOR
Post by TRANTOR »
Subj.
No more pauses in WDM. WOW! :D
Mark S
Re: New drivers available: 3.6.8.1414
Post by Mark S »
any round rip latency specs?
TRANTOR
Post by TRANTOR »
No other changes vs previous release.
robleighton22
Post by robleighton22 »
they install without any issues on windows 7 - previous drivers required me to use compatability mode (in fact the last drivers just didn't work very well at all for me). got a few pauses, but it does seem to be working better. as always, only time will tell, often takes a few days for any issues to start appearing. at the moment they are working well.
tim_booth
Post by tim_booth »
hi all
just to mention my experience.
all late drivers have problems (1400,1410,1414).
for example nuendo 3 does not work or work without spdif.
last working version was 32fw-3.6.8.1394
my system:
mb asus P5E3, WINXP SP3, MOTU 828MK2 (FIRMWARE 1,01 HARDWARE 1,01), NUENDO 3,2 CUBASE 3,2.
so this 1414 driver has the same no spdif problem.
anyone with same probs?
thanks
HotShot
Post by HotShot »
I'm using SONAR 8.3.1, and all the ASIO output routings are working correctly, here.
I'm using the Vista 64bit version of .1414, and .1410 and .1414 works correctly, in my experience.
I've read in the SONAR forum that .1414 even improves the WDM, WaveRT, performance, though I haven't really tested other than ASIO.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
tim_booth
Post by tim_booth »
hi HotShot, thanks for the reply
obviously you don't have the 828 mk2 usb that i use, and you don't use nuendo or cubase.
as you understand these drivers are for general use for all firewire/usb motu devices and this means that may improve or fix something in one device but bug another.
they motu techs should test every model with these and mention in the new release what is new and for which model.
anyone here with 828 mk2 usb testing the latest drivers?
thanks
shefu
Post by shefu »
these drivers don't seem to work for me, could somebody upload the vista 32bit .1410 drivers for me please? i can't find them anywhere
Vista Home Premium (32bit)
Intel 2Quad Q6600 2.4Ghz
Ram 3GB
Ultralite MKIII
Using Live 7.03
TRANTOR
Post by TRANTOR »
jmARC
Post by jmARC »
Hi.
I'm having trouble with this configuration:
Windows 7 64 bits
Cubase 5 64 bits
MOTU 828 MK2
I installed the drivers without problems, but Cubase is not capable of detecting the card. It says there is no VST hardware installed.
The system is new, so I don't have any earlier versions of the 64 bits drivers to try out.
Do you know what could be the problem?
Thanks.
osmuzikradio
Post by osmuzikradio »
I tried for days to get the 1414 drivers to work with no luck. The fw3.6.8.1410 drivers do work tho by installing them in compatibility mode Vista SP1 and run as admin (all users). I also run all the Motu stuff (CueMix and so on even Cubase) in the same compatibility mode as well. There is another issue with some motherboards where the firewire controller driver needs to set to the legacy. I didn't have to do that but it is another work around to try.
Core i7 920, Intel DX58SO, 1600 Mhz DDR3, Radeon HD 4890, Win 7 RC 64, Macbook 2.2 Ghz, Power Mac G4 Dual 1.42 Ghz, eMac G4 1.25 Ghz, OSX 10.57, Motu 828 mk2 FW, Presonus Firestudio Project, Emu 0404, Cubase 4, Logic Express 6, Logic Pro 7, Logic Studio, Sonar Producer 8.
