Trouble with Bussing for submixing
bannerj
Post by bannerj »
Just bumped from 5.13 to 6. I use submixes extensively throughout my projects. Some of the busses are not making it into DP 6. In fact a few songs won't even work with my master fader. Once I deleted the master fader I got most of my tracks to work, but then there were a few groups that were still silent (I could still see levels on the meters but no sound). So, I deleted those subgroups and then made new busses...still a problem...no sound.
I've noticed this before with 5.13. When i go into the bundles matrix and move the buss number assignments around sometimes the sound would go blank or sometimes I'd only get a mono signal through a stereo pair.
Help!
bannerj
Re: Trouble with Bussing for submixing
Post by bannerj »
Some new very weird bugs here: sometimes I can't get sound to pass through my URS CSP plug unless I'm looking at the GUI??? When I hide the GUI the sound goes away?
stephentayler
Post by stephentayler »
Try setting your plugs to run in real time
Busses are all working fine here in DP6.02, and I use a lot of busses in my stereo and 5.1 mixes.
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Tim
Post by Tim »
I too have had buses quit working in a project, but still be fine in another similar project (same template).
I haven't taken the time to figure out what the deal is yet.
bannerj
Post by bannerj »
stephentayler wrote:Try setting your plugs to run in real time
Stephen
Sorry, "real time"? What do you mean?
stephentayler
Either check Run This Instance in Real Time on the plugin dropdown menu, or have a look at Preferences>Audio Plugins
Without this plugins are pre-rendered when the window is closed, and maybe there is a problem with this plugin, I personally don't have this one!
Cheers
Stephen
