Just bumped from 5.13 to 6. I use submixes extensively throughout my projects. Some of the busses are not making it into DP 6. In fact a few songs won't even work with my master fader. Once I deleted the master fader I got most of my tracks to work, but then there were a few groups that were still silent (I could still see levels on the meters but no sound). So, I deleted those subgroups and then made new busses...still a problem...no sound.
I've noticed this before with 5.13. When i go into the bundles matrix and move the buss number assignments around sometimes the sound would go blank or sometimes I'd only get a mono signal through a stereo pair.
Help!
Trouble with Bussing for submixing
Re: Trouble with Bussing for submixing
Some new very weird bugs here: sometimes I can't get sound to pass through my URS CSP plug unless I'm looking at the GUI??? When I hide the GUI the sound goes away?
Try setting your plugs to run in real time
Busses are all working fine here in DP6.02, and I use a lot of busses in my stereo and 5.1 mixes.
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
I too have had buses quit working in a project, but still be fine in another similar project (same template).
I haven't taken the time to figure out what the deal is yet.
Sorry, "real time"? What do you mean?stephentayler wrote:Try setting your plugs to run in real time
Stephen
Either check Run This Instance in Real Time on the plugin dropdown menu, or have a look at Preferences>Audio Plugins
Without this plugins are pre-rendered when the window is closed, and maybe there is a problem with this plugin, I personally don't have this one!
Cheers
Stephen
Cheers
Stephen
