ultralite MK3...hmmm
hey guys!
im new to production and just purchased a motu ultralite mk3. just want to know from others out there using this interface. is it normal for sounds in windows/mp3s in windows to have a slight delay when they play? for instance when i first start up the mk3, and open an mp3 file it begins playing for about 1-2 seconds before any sound comes out of my speakers. and same with opening folders in windows, it seems to miss play the whole sound and only play the last bit of sounds. this doesnt happen all the time though, if iam listening to mp3 or using the sound card then it seems fine. soon as you let it idle for a 30seconds or so, it seems to go into sleep or standby mode and do the 1-2 second delay thing again.
also how bout this little nugget: when i first turn on the ultralite and turn up the volume, the headphone volume is default at start up? why is this? wouldnt it be main volume, then click down for headphone volume second? strange??
is this normal? i doubt it is, and i doubt it is a problem with my ultralite as it works fine in cubase... it might be some other kind of problem?
my pc is a intel i7 920 with a gigabyte ex58-ds4 motherboard and 6gb ddr3. iam running xp32. also i have installed the latest driver from motu (.1400
or something similar) i might revert back to the one with the cd and see how that goes...
any ideas?
thanks.
any ideas?
thanks.
INTEL i7 920
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
Re: ultralite MK3...hmmm
Have you checked the buffer for a latency setting ?
Forget the buffer... I dont think it is a motu issue, something in your hardware setup is wrong - Firewire ? Try changing a card with FW... I dont know what else...
thanks for the replies fellas....
the firewire port is a texas instruments... i had a motu ultralite mk1 before this one on this same pc and i never got the delay?
INTEL i7 920
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
- Primary DAW OS: Windows
I was seeing a similar delay problem with the newest driver (3.6.8.1400), but it only occurred after I installed the driver and rebooted. Then, it went away. I'm using Vista 64-Bit, and I I have windows sounds off.
You may want to report these issues via a MOTU TechLink.
I didn't and don't experiece this delay with the 3.6.8.1400 driver. Maybe you can try this driver: http://babelfish.yahoo.com/translate_ur ... =yfp-t-501
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
SONAR X1a Producer
thanks ill give it a shot.
cheers!
cheers!
INTEL i7 920
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
hotshot, just tried that new driver .1410, it is still doing the delay thing. not that its a big deal but i just wanted to know if thats normal or not.
anyway thanks
anyway thanks
INTEL i7 920
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
No, that's not normal. I have also installed the new 3.6.8.1410, and I don't have that delay.
You may need to contact MOTU tech support. Also see if raising the hardware buffer sizes in Audio Console will help.
SONAR X1a Producer
SONAR X1a Producer
