Mackie Control Universal (MIDI) and Audio MIDI Setup
I use a Mackie Control Universal (MIDI version). I connect it via the MIDI ports on the 828mk3. Each time I open Digital Performer I must go into Audio MIDI Setup and reconnect the control surface. Once the connections are redrawn, it works fine. However, if I hit "Rescan MIDI" or if I quit DP, the connections disappear. This is a relatively new development as previously I would connect it once and it would remain connected. I'm not sure what has changed. Any help would be appreciated. I'm not sure if this is an issue with DP or with the 828mk3.
Traveler, 828mk3, MBP 2.16GHz 3GB, DP5.11
- Dwetmaster
Re: Mackie Control Universal (MIDI) and Audio MIDI Setup
Does it happen with any connected MIDI device or the MCU only?
I don't use any other MIDI devices. I have pulled the Traveler out of the rack and connected the MCU via the MIDI ports on the side of the Traveler and it has the same problem. I was hoping that this was something in Digital Performer that could easily be solved. I'll pick up some new MIDI cables this week and try that, too. If it's not something in DP, and it's not the cables, then I guess it's the MCU.
I, among several others here, have been experiencing the same thing since we upgraded to Motu's 1.4.20 driver. I gotta Mac Pro(Jan 2008) running OS 10.5.6 with DP 5.13. Interface is 828MK II and Mackie Control. It never happened before installing the latest driver. Well....at least for me. I can't speak for any of the others.
*14 inch M1 Macbook Pro - 16GB Ram - OS 15.4.1 (Sequoia)- Motu M4 - Motu DP 11.34+97919, Other bells and whistles*
Interesting. I did update CueMix in late January early Feb, which included an updated MOTU driver (I think). Thankfully this is not a major issue, only a minor annoyance.
Indeed.
- cloudsplitter
I have the latest drivers and the mackie control universal and one mackie control extender unit in DP-6 latest version and it works flawlessly.
Some folks (self included) picked up this problem after installing the latest MOTU USB drivers. The solution is to go back to the previous version (1.49 I think). I thought this only affected the 828MK2 users though.
There are a few threads on it floating about already on the forum.
A bit of a PIA.
A bit of a PIA.
Mac Studio | 96 GB RAM | OS 15.4 | LIVE 12 | CUBASE 14 | DP 11 | MOTU Interfaces | Waaay Waaay Too Many Plug-ins (but I'm improving!)|
http://www.gesslr.com
- cloudsplitter
I forgot to add, I'm using the traveler..!! and a MIDI express XT...(if any of that maters)
Mac Pro 3,1 8 core 12 gigs ram Mavericks. DP-8.05 Fractal Audio Axe-FX Ultra, motu traveler, motu MIDI express, 2-24" LCD monitors, Yamaha HS80M,Yamaha NS10M's JBL28P monitors. Mackie control universal, BFD-2, Omnisphere,Trilian Ozone 4, Melodyne Studio/Editor, . Alesis Masterlink. Avalon 737sp. PCM 90. MikTek C4V. Korg Triton Extreme. Paul Reed Smith guitars, MPC-2500 there's more..but that's the heart of it.
