I've had this piece of equipment for about 4 years now. I know that I had trouble installing it each time (this is the third time), I just can't figure out for the life of me what I did to get it to work. I called tech support and I haven't gotten any help at all. They kind of just mumbled on the phone, said they didn't know and put me on hold.
But more or less, I used the installation disc that came with the 896HD (24-Bit 192 Khz Firewire). After installing and reinstarting, I turn the MOTU on and it isn't recognized. I thought I remember having to install the drivers from the website because there was an error with the disc or so they said. So I uninstalled it, and downloaded the drivers from the website. Installed them, and repeated.
However, everytime I click on the MOTU options in the start menu. It says No MOTU device is found. I'm on Vista now. I was on XP before.. I just can't figure it out. The computer is well equipped so it should work.
Any help would be much appreciated. Thanks in advance.
Trouble Installing MOTU 896HD
Re: Trouble Installing MOTU 896HD
What happens when you power cycle it?
MacPro2.66/3GB/828mk3/Rosetta800/UAD-2Quad/Waves/
I'm sorry. What do you mean by power cycle? I'm pretty clueless.
Thanks in advance.
Thanks in advance.
Sorry, I'm an idiot. I looked back at this and thought about it.
Nothing happens. I hear a beep when it restarts on the computer but nothing pops up anywhere and I can't find anywhere on the computer to where I might be able to further the process. I install the drivers without the MOTU plugged in. Restart the computer with it plugged in and nothing. I can't get it installed and it's driving me crazy.
What does the driver info say? By that I mean, when you start up the driver manually?
You've reinstalled the driver?
Maybe from your statement you cant figure out how to start up the driver. Do a search for MOTU Audio Setup.
