DP 6:02: Stillwell Plugs Issue
Re: DP 6:02: Stillwell Plugs Issue
pheelthemusic wrote:
James Steele wrote: Yeah, but what's weird is that I had a couple other of your Stillwell plugs (probably expired demos) in the folder already so it wasn't ever a single plug by itself. It's more like what 666 said perhaps. I've written to MOTU a number of times about how their plug-ins appear. They never appear as neatly as they do in Logic. I even wrote to them a detailed description of adding user-created categories and sorting them according to those (they'd of course need to use a prefs file for DP to keep track of it). For example, users could create categories called "Compression" "Delays" "Reverbs" and whatever made sense to the users. When you get many plugs, sorting by manufacturer isn't necessarily that useful.
+1,000
+ a kazillion.
EMRR
Post by EMRR »
Here's one I'm noticing. If I go back and forth between the G5 and the MBP with the same session, any Stillwell plug settings made on one system do not exist on the other system upon transfer. All controls are set to a default zero position after transfer. That's a bit of a deal-breaker; is there a work-around? How would you pull up a session on a different system a year down the road? Save a preset for any setting used, and move the presets with the DP session to the other system? I checked a few instances with known saved user presets, and they don't reload if toggled. Maybe it's a GUI issue? I need to save an instance with an extremely audible setting and check that.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
EMRR
Post by EMRR »
Doug Williams
Tape Op issue 73
DP 11.34
timriley
Post by timriley »
I just tryed the oligarc suite on my system and im sorry to report that 'sticky knob syndrome' seems to have infected them too..
It's definitely the latest version.... Haven't tryed the other schwa stuff...
Mac Pro Quad XEON/2.8Ghz/12GB RAM
Macbook Pro Core Duo/2.16Ghz/2GB RAM
OSX 10.6.8/DP7.22
sstillwell
Post by sstillwell »
timriley wrote:I just tryed the oligarc suite on my system and im sorry to report that 'sticky knob syndrome' seems to have infected them too..
Thanks for that, I'll pass it on to schwa.
Scott
bootsncats
Post by bootsncats »
In reply to my previous posting on this thread: My Rave continues.
I just did a live show tonight full band acoustic guitar, violin, ect. Using the rocket compressor. I was approached by several audio guys after the show and they thought it was uad, or waves. I said it was better: it was stillwell. I'm not sure how often it has been used in a live environment but it was AMAZING. I even ventured into using the audio gain comp. magic. Thanks again Scott!
http://midsummer.dreamhosters.com
8 core 3.0Gzh 12 GB Ram 3 TB Storage
DP7.01,STILLWELL and all the rest
896HD, Traveler,003, AK1, Euphonix MC control, Mackie MCU, Iphone
