Can't open DP or Audio/MIDI setup?
melodesiac420
Post by melodesiac420 »
Everytime I open DP I get the "pinwheel" and it tells me it can not open DP because the MIDI has crashed. Then, when I try to open my Audio/MIDI setup from the utilities menu I get the pinwheel again, then it quits by itself and gives me the pop-up that asks if I want to "send a bug report to apple?"
I hope this is just something stupidly simple.
BTW, I did run Onyx software yesterday, did I perhaps change a setting in Onyx that would have screwed up my MIDI?
Any advice is greatly appreciated.
Melodesiac420
Ibook G4 1.2 gHz
OSX 10.3.9
DP 4.52
Spectrasonics Stylus
MTP AV (usb)
M-Audio FirewireSolo
Yamaha O3D
<small>[ August 01, 2005, 07:56 PM: Message edited by: melodesiac420 ]</small>
I'm not really a smartass..... However....I did stay at a Holiday Inn Select last night.
azusa749a
Re: Can't open DP or Audio/MIDI setup?
Post by azusa749a »
If I were you, I'd trash DP preference and redo the MIDI set up again.
One thing about Onyx, it'll delete a connection from any document and the application.
It happens to me everytime I use it, even I uncheck the delete connection. :roll:
qo
Post by qo »
When it crashes next time, and asks if you want to send a report to apple, click the "Send Report" button (at least I think that's what the button says). Then Cmd-A in the resulting screen to select all, then Cmd-C to copy. Open TextEdit or some other app and Cmd-V. Look through this and find where it says:
Thread x (crashed)
Where x is some number. Copy the contents of that thread and paste it here. We can go from there.
In the meanwhile, you could try reinstalling the latest MOTU USB driver. If that doesn't work, you might think about trashing Audio/MIDI Setup prefs (I can let you know where these are located when I get home later tonight).
qo
Post by qo »
OK, the AMS configurations are stored in:
~you/Library/Audio/MIDI Configurations
"~" is unix for "path to home directory" e.g. if I'm user qo, and I have a directory in my account called "foo" then, in Terminal, the following will get me there from anywhere:
cd ~qo/foo
Anyway, you might try dragging these to your Desktop and rebooting. If the problem goes away, then you can rebuild your MIDI setup from scratch. If the problem remains, we can try other things...
melodesiac420
The problem remains.
Here's the bug report... It'sprobably alot more than is needed, but, oh well, perhaps i can go back and delete the non-useful portions later.
Here we go...
Thread 0 Crashed:
0 com.apple.CoreFoundation 0x901c680c CFStringGetLength + 0x34
1 com.apple.CoreFoundation 0x901cb2f4 CFStringCompareWithOptions + 0x140
2 com.apple.Foundation 0x90a27100 -[NSString compare:options:range:locale:] + 0x64
3 com.apple.Foundation 0x90aa1974 -[NSString localizedCompare:] + 0x88
4 com.apple.audio.AudioMIDISetup 0x0000af40 0x1000 + 0x9f40
5 com.apple.audio.AudioMIDISetup 0x0000a990 0x1000 + 0x9990
6 com.apple.AppKit 0x92f27b2c -[NSApplication sendAction:to:from:] + 0x6c
7 com.apple.AppKit 0x92f2e848 -[NSControl sendAction:to:] + 0x60
8 com.apple.AppKit 0x92f68b28 -[NSCell _sendActionFrom:] + 0x9c
9 com.apple.AppKit 0x92f08580 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 0x3fc
10 com.apple.AppKit 0x92f79738 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 0x234
11 com.apple.AppKit 0x92f3e918 -[NSControl mouseDown:] + 0x218
12 com.apple.AppKit 0x92eb2a24 -[NSWindow sendEvent:] + 0x10e4
13 com.apple.AppKit 0x92ea50d0 -[NSApplication sendEvent:] + 0xebc
14 com.apple.AppKit 0x92ead500 -[NSApplication run] + 0x240
15 com.apple.AppKit 0x92f69bec NSApplicationMain + 0x1d0
16 com.apple.audio.AudioMIDISetup 0x000081fc 0x1000 + 0x71fc
17 com.apple.audio.AudioMIDISetup 0x00008070 0x1000 + 0x7070
Thread 1:
0 libSystem.B.dylib 0x90007878 mach_msg_trap + 0x8
1 libSystem.B.dylib 0x900073f8 mach_msg + 0x38
2 com.apple.CoreFoundation 0x901c16e0 __CFRunLoopRun + 0x350
3 com.apple.CoreFoundation 0x901c5e6c CFRunLoopRunSpecific + 0x148
4 com.apple.audio.CoreAudio 0x948fd4b8 _ZN10HALRunLoop9OwnThreadEPv + 0x104
5 com.apple.audio.CoreAudio 0x948fd2ec _ZN9CAPThread5EntryEPS_ + 0x30
6 libSystem.B.dylib 0x90024910 _pthread_body + 0x28
Thread 2:
0 libSystem.B.dylib 0x900127b8 syscall_thread_switch + 0x8
1 com.apple.Foundation 0x90a33330 +[NSThread sleepUntilDate:] + 0x98
2 com.apple.AppKit 0x92e7a880 -[NSUIHeartBeat _heartBeatThread:] + 0x494
3 com.apple.Foundation 0x90a6a510 forkThreadForFunction + 0x6c
4 libSystem.B.dylib 0x90024910 _pthread_body + 0x28
PPC Thread State:
srr0: 0x901c680c srr1: 0x0200f030 vrsave: 0x00000000
cr: 0x24004242 xer: 0x20000000 lr: 0x901c67e0 ctr: 0x9011c008
r0: 0xa01c05f4 r1: 0xbfffe5b0 r2: 0xa01c01f4 r3: 0x40701000
r4: 0x00000000 r5: 0x00000000 r6: 0x00000000 r7: 0x656e006e
r8: 0x656e0000 r9: 0x0000001c r10: 0x00000000 r11: 0x00000000
r12: 0x00000000 r13: 0x00000000 r14: 0x00000100 r15: 0x00000000
r16: 0x00000001 r17: 0x00000000 r18: 0x00000000 r19: 0x00000030
r20: 0x00000000 r21: 0x00000000 r22: 0xa2e98184 r23: 0x001ab030
r24: 0xa2e98a8c r25: 0x001a4790 r26: 0x00000000 r27: 0x00000000
r28: 0x40701000 r29: 0xbfffe790 r30: 0x40701000 r31: 0x901c67e0
Binary Images Description:
0x1000 - 0x3afff com.apple.audio.AudioMIDISetup 2.0 /Applications/Utilities/Audio MIDI Setup.app/Contents/MacOS/Audio MIDI Setup
0x7c8000 - 0x7c9fff com.apple.aoa.halplugin 2.5.0 /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x808000 - 0x83afff com.apple.iSightAudio 7.0 /Library/Audio/Plug-Ins/HAL/iSightAudio.plugin/Contents/MacOS/iSightAudio
0x80830000 - 0x8090efff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x88ec0000 - 0x88efefff com.apple.audio.MIDI.CoreMIDI 1.4 (29) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x8fe00000 - 0x8fe4ffff dyld /usr/lib/dyld
0x90000000 - 0x9014ffff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901c0000 - 0x9026dfff com.apple.CoreFoundation 6.3.7 (299.35) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x902b0000 - 0x90529fff com.apple.CoreServices.CarbonCore 10.3.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90584000 - 0x905f3fff com.apple.framework.IOKit 1.3.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90610000 - 0x9069afff com.apple.CoreServices.OSServices 3.0.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90700000 - 0x90700fff com.apple.CoreServices 10.3 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x907f0000 - 0x907f9fff com.apple.DiskArbitration 2.0.5 /System/Library/PrivateFrameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x90810000 - 0x90810fff com.apple.ApplicationServices 1.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x90830000 - 0x9089ffff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90940000 - 0x909b3fff com.apple.DesktopServices 1.2.5 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x909f0000 - 0x90a04fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x90a20000 - 0x90b7bfff com.apple.Foundation 6.3.7 (500.59) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x90ceb000 - 0x90d08fff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x90d20000 - 0x90d3bfff com.apple.SystemConfiguration 1.7.1 (???) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x90ec0000 - 0x90ec0fff com.apple.Cocoa 6.3 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x910b0000 - 0x91101fff com.apple.bom 1.2.5 (63.2) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x913a0000 - 0x9145ffff ColorSync /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x914ad000 - 0x914c0fff com.apple.speech.synthesis.framework 3.2 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x914e0000 - 0x91549fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x915e0000 - 0x91699fff com.apple.QD 3.4.67 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91720000 - 0x917b3fff com.apple.print.framework.PrintCore 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91820000 - 0x91830fff com.apple.speech.recognition.framework 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x91850000 - 0x9186afff com.apple.openscripting 1.2.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x91890000 - 0x918a0fff com.apple.ImageCapture 2.1.5 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x918d0000 - 0x918dcfff com.apple.help 1.0.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x91900000 - 0x9190dfff com.apple.CommonPanels 1.2.1 (1.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x91930000 - 0x9197efff com.apple.print.framework.Print 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x919a7000 - 0x919b2fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x919d0000 - 0x919dbfff com.apple.securityhi 1.2 (90) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x919e3000 - 0x91a1bfff com.apple.AE 1.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91a40000 - 0x91ab3fff com.apple.NavigationServices 3.3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x91b10000 - 0x91b2afff libPDFRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPDFRIP.A.dylib
0x91b50000 - 0x91b5ffff libPSRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPSRIP.A.dylib
0x91f0d000 - 0x91f0dfff com.apple.Carbon 10.3 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92056000 - 0x9206dfff com.apple.LangAnalysis 1.5.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x920f0000 - 0x92116fff com.apple.FindByContent 1.4 (1.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x92140000 - 0x92327fff com.apple.security 2.4 (177) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x924b0000 - 0x924e8fff com.apple.LaunchServices 10.3.5 (98.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x927a7000 - 0x927c1fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x927f0000 - 0x92827fff com.apple.CFNetwork 1.2.1 (7) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x92880000 - 0x92c05fff com.apple.HIToolbox 1.3.6 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92e70000 - 0x9336ffff com.apple.AppKit 6.3.8 (743.39) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93a20000 - 0x93a34fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x93a50000 - 0x93a54fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x93bbc000 - 0x93c74fff com.apple.audio.toolbox.AudioToolbox 1.3.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x940f0000 - 0x94108fff com.apple.WebServices 1.1.1 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x94640000 - 0x94649fff libz.1.dylib /usr/lib/libz.1.dylib
0x9464c000 - 0x9469cfff com.apple.HIServices 1.4.1 (0.0.1d1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x946e0000 - 0x9473ffff com.apple.SearchKit 1.0.2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94800000 - 0x9488cfff com.apple.ink.framework 101.1.4 (55.12) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x948fa000 - 0x94961fff com.apple.audio.CoreAudio 2.1.3 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x949ba000 - 0x949cdfff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94ea0000 - 0x954a6fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95500000 - 0x957d0fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x958e0000 - 0x95900fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x95b50000 - 0x95c32fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x95ca0000 - 0x95d62fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x95dc0000 - 0x95deefff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
0x95e40000 - 0x95eadfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x95f30000 - 0x9601efff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x962e6000 - 0x965befff com.apple.CoreGraphics 1.203.30 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x96b50000 - 0x96bdffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96e80000 - 0x96e90fff com.apple.vecLib 3.0.3 (vecLib 3.0.3) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x970f0000 - 0x970f8fff libbsm.dylib /usr/lib/libbsm.dylib
0x9798b000 - 0x9798bfff com.apple.audio.units.AudioUnit 1.3.3 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
melodesiac420
Oh Yeah... And thanks for your help...Much appreciated.
qo
Post by qo »
I'd try moving /Library/Audio/Plug-Ins/HAL/iSightAudio.plugin to the Desktop and rebooting. This particular plugin has been a source of trouble with DP (crash on quit) before. I'm not sure what the relation is, but it's worth a try. If you're using iSight, this'll be a pain :-(
No doubt you're crashing in AMS/CoreAudio. Also, when you upgraded to 10.3.9, did you use Software Update, or did you download the Combo Updater? If you used Software Update, you may want to download the Combo Updater from Apple and reinstall that. It won't hurt anything to do this. The reason I ask is:
This could be perfectly normal, but seems sort of weird to me. Installing the Combo Updater will ensure that all system components are updated.
chucks
Post by chucks »
Try uninstalling and then reinstall the MTP AV drivers. If for some reason the MTP AV is powered off or momentarily disconnected while everything is up and running, the driver (or supporting files) somehow get corrupted. Not being able to run Audio MIDI Setup and DP hanging are symptoms of this driver corruption (at least in my experience).
melodesiac420
I'm up and running. Thanks to everyone that jumped on here and offered up their personal knowledge. I swear... everytime I come in this messageboard I learn about 10 new things.
As it turns out, I had reinstalled the usb MIDI drivers, however, I didn't uninstall before I did. When I uninstalled, reinstalled and rebooted w/my MTP AV on, all is good in the neighborhood again. Audio/MIDI setup opens without a hitch and sees my MTP AV, thenI fired up DP and vavoom, running smooth again.
Thanks again to those that helped me.
melodesiac420
