How To Avoid Crashes
Perhaps you all have discovered these things, but if not--
I always:
1. Reformat before updating OS or DP.
2. Log off before shutting down.
No, it's not a long list, but a good one, I think.
I hope others will put up their ideas on this.
I always:
Re: How To Avoid Crashes
Hello:
If you have a slower system, turn off the playback scubber (speaker icon). During edge edits and the like it overloads the buss and unexpectedly quits.
<small>[ April 26, 2005, 09:29 AM: Message edited by: Don T ]</small>
It's the ear, not the gear!
MacPro 2.66 gHz 12 core (dp 10.01) - Lynx Aurora16 - OS 10.12.6/WaveArts/TruePianos - Legend 32ch console - G16 Fostex
(2) MacPro 2.66 gHz 12 core (DP 9.5) OS 10.12 - 24 I/O - 2408 mk2 - Da7- (PT 12) - 8 trk MCI
MacPro 2.66 gHz 12 core - OSX 10.12 - Genesys Black - Lynx Aurora16 - waves - Oxford - McDSP - 16 trk Otari - analog sweetness
Man, you must have a lot of free time.Originally posted by fbkaiser:
DP 7.24
Macpro
OS 10.7
Macpro
OS 10.7
Actually, I have no free time. I spend all of my workday recording and have no time to spend on screw-ups in my system. I don't update so often that the thorough cleansing of the drive amounts to anything like the time I could waste jacking around with it trying to get it to work.
Well, what ever works for you of course. I'm guessing you don't have many plugs or VIs to re-authorize each time. For what it's worth I've never done either of those steps and don't have crashing problems. However, I do repair pemissions before and after any install of anything.
DP 7.24
Macpro
OS 10.7
Macpro
OS 10.7
- donreynolds
Hey Dan,
Could you tell me how to repair permissions and what is the reason to do so?
I have never done that before.
also, is it safe to trash any preferences? I hear people say to trah DP prefs sometimes when there is a problem. will they reload automatically when you re-boot?
Mac Studio M2 OS 15.3 Sequioa, Presonus Faderport 8, 150gig Raptor x 2, Glyph 2Tb drive DP 11.33, Antelope Discrete 8, BLA microclock ll, Presonus Central Station, Waves Plat. V7 , Slate Everything, Melodyne studio, SSD 5, TruePianos, Event 20/20 bas, Adam A7, Avantone Active MixCube, and other toys, Lotsa guitars, HeadRush GTR processor and a Korg Triton)
Excellent article and tool (Applejack):
http://www.macfixit.com/article.php?story=2005041817191411
Kris....
Kris....
- dixiechicken
Hi Don!
You start DiskTool in /Applications/Utilities-folder
You can only repair permissions on the bootdrive
Mac OS-X have a standard set of permissions on every file in the system. (for things to work properly)
For some reason many installers seem to mess up these permissions.
This can i worst case make programs stop working
or at least screw things up pretty bad.
( if you suddenly lost permissions to save files in a certain folder - perhaps you couldn't save your newly recorded audiofile - as an example)
Cheers: Dixiechicken
My God it's full of stars....
Mac Pro 6-Core Intel Nehalem/Xeon 2.93 GHz 32-GB ram, OS-X 10.13.5-Swe, DP-9.52, Unisyn-2.11, 828-MkII,MTP-AV usb, Latest drvs, Wavearts plugs, Kurzweil-2000, Proteus-2000, EPS-16, Pod-II,
Digitech RP-155, Soundcraft UI-16, Emes Kobalt monitors.
- Shooshie
Maybe those are valid points. I don't know. But I don't do either one, and I have no problems with DP.Originally posted by fbkaiser:
I always:
Same here.Originally posted by Shooshie:
I always:
I wonder how logging off would even affect, let alone benefit, DP stability.
That said, if it works for ya, gotta love it.
- Timeline
Sooshie is right about log offs.
External FW, scsi or USB drives can sometimes hang up a shutdown command.
Log offs seem to help somehow and they are faster but I don't know why.
I believe your permissions question has been answered. Trashing prefs when there's an application specific problem can help but figuring out which one to trash is tricky. In OS9 it was a simple matter but in OSX there seems to be multiple pref files for everything. I would imagine most of them would regenerate after trashing but I haven't had to do it enough to really advise you.Originally posted by Don Reynolds:
Hey Dan,
DP 7.24
Macpro
OS 10.7
Macpro
OS 10.7
Try Jonathan Nathan's "Preferential Treatment" free utility that checks for corrupted System and User Level Preference files atOriginally posted by Dan Weiss:
Hey Dan,
http://homepage.mac.com/jonn8/as/html/pt.html
It received a 5-star rating from VersionTracker.
Kris..
<small>[ April 26, 2005, 08:57 PM: Message edited by: mastermix ]</small>
Ah Ha.... That explains it. I have that happen too & it's so annoying. Actually it happens to me if I edge edit during playback, you know like you've found a spot you need to edit during playback so you amke the edit-Ooops crash. But, ya know you'd think on a dual 1.25 G4 simples things like this wouldn't happen.Originally posted by Don T:
Hello:
Thanks Don T
Cheers
*Dual 1.25 G4 2GB RAM/OS 10.5.8/DP 4.6.1/UAD-1/Powercore/Virus PoCo/NI/ EWQL/MX4/Symphonic Instrument/Novation V-Station,Nova/Green Oak-Crystal, Orbit, Dark Star
*Dual 2.0 G5 PowerPC 6GB RAM/OS 10.5.8/PT 8/DP 6/UAD-1/Powercore
*Core Duo 1.83 Macbook Pro/OS 10.5.8/PT 8/DP 6 and um....
*5) ultra bad Strats/Egnater Tourmaster 4100/Carvin Legacy/Laney 100W AOR/4x12 Celestions
*Neumann/AKG/Shure
http://home.comcast.net/~keith_henry/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
*Neumann/AKG/Shure
rather than have to re-authorize plugins it is nice to have a mirror of your drive before you update, so if the new update is screwing things up just switch to the other OS... yes it requires 2 HDs
but it is *the* way to go
