MOTU Universal Audio Install- OSX, 1.4.20
nick danger
Post by nick danger »
http://www.motu.com/download/download_m ... duct_id=14
This install provides compatibility updates for Mac Intel processors, OS 10.5, and is compatible with OSX versions back to OSX 10.4.x.
Installer contains a driver update for the MOTU 828, 896, 828mk2, 828mk2 USB, 896HD, Traveler, UltraLite, 8pre, 828mk3, 896mk3, UltraLite mk3 and Traveler mk3. Cuemix console supports external control surfaces, talkback & listenback capabilities, and I/O port names.
Any takers?
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Re: MOTU Universal Audio Install- OSX, 1.4.20
Anybody?
Dwetmaster
Post by Dwetmaster »
It's been working good these last two days...
rcmusic
Post by rcmusic »
I use a motu 828 mk2 usb with logic pro (last version) on leopard (las version). since i instal those drivers i have a lot of noise/glitches. i have tried all (repair permi, trash pref...). unfortunately i don't have anymore the previous driver version (20 spetember 2008),
thanx so much
richard from france
edit: ok i found the driver 1.4.9 on VT, reinstalled and now the sound is ok again...... any idea?
hottlungs
Post by hottlungs »
i've installed this a few times but i have yet to experience cuemix the way that it is described in the pdf... or with 8 busses instead of 4 as was explained when they unveiled the motu traveler mk3. where is the FFT AND SPECTROGRAM DISPLAY that was mentioned in the addendum? is this not the update that was promised and if so, why would they attach the pdf addendum with features it doesn't have?
dBIV
daniel daniel
nick danger
What interface are you using?
hottlungs
Post by hottlungs »
an original traveler. i wasn't expecting the mk3 specific features obviously... but according to their site and an overview from CDM, it appeared that some of these features would be compatible with the original traveler/ultralite/828 ect.
http://www.motu.com/products/cuemix-fx/overview.html
daniel daniel
nick danger
I really haven't tried doing anything more with Cuemix FX on my 828mII than I did with the old Cuemix, but I think the upgrade when used on older units is mostly just a different GUI. Aren't most functions pretty much the same? Maybe someone else can fill us in.
hottlungs
Post by hottlungs »
hmmm, i would think that the cuemix features that do not rely on new hardware (basically everything but the effects) should be a feature of the new cuemix software, not an extension of the new hardware.
from CDM Traveler MK3 review: "If you own another MOTU unit, you’ll be relieved to know the CueMix software features will be available for download on other FireWire audio interfaces."
I want the M-S routing feature and the extra 4 busses and the spectrogram and the FFT display. Pretty please?
dBIV
daniel daniel
Actually, I think this is version 1.4.8. It has the exact same file size and release date of 1.4.8. This isn't the first time VT has screwed up MOTU releases. Does anyone know how to tell what is the driver package version without actually installing it?
1nput0utput
Post by 1nput0utput »
hottlungs wrote:from CDM Traveler MK3 review: "If you own another MOTU unit, you’ll be relieved to know the CueMix software features will be available for download on other FireWire audio interfaces."
If that's what the review says, then it's wrong.
hottlungs wrote:I want the M-S routing feature and the extra 4 busses and the spectrogram and the FFT display. Pretty please?
M-S matrixing and the additional four mix buses are a feature of the hardware, not the CueMix FX software. The spectrogram and FFT analysis are CueMix FX software features, but it makes sense that MOTU would make then compatible only with the new line of FireWire interfaces. They need to create reasons for owners of older interfaces (such as the original Traveler) to upgrade to newer ones.
stephentayler
Post by stephentayler »
This is what it says on the first page of the installer
FFT and Spectrogram display
for the mk3 series of MOTU Firewire Audio Interfaces
cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
woodshedder
Post by woodshedder »
I hope this driver will get rid of the drop-outs and the high pitched beeps on my 828mk3:!:
eldar101
Post by eldar101 »
:shock: Hi i have a problem !!!!!
have the motu 828 mk2 USB
new driver
osx 10.5
and it works only without weigher
i plug it in and the sound is gone
HHHEELLLPP pleace!!!
stay tuned
eldar
rcmusic
Post by rcmusic »
File Name: MOTU_Audio_Installer090311.zip
Type: driver
Date: 2009/03/11
Language: english
Version: 1.4.20
Platform: Mac OSX
1.4.20 came back on march the 11st ?? can omeone explain or tel if something has changed. thanx
