can't open CueMix FX Console !
alex82
Post by alex82 »
Hi together
I have a problem with the motu828 mk3 and the CueMix FX aplication. If i want to open the console with dobbel click the "Motu CueMix FX Console", no window ore desk is appearing. Only below in the dock is showing me that the aplication is open.
Does anybody know what could be the problem?
regards alex
whentomorrowfails
Re: can't open CueMix FX Console !
Post by whentomorrowfails »
i have that same problem! i'm new to a Mac, but at least on Windows, it'll attempt to open, even though it tells me that there was no MOTU device found... b/c for some reason my laptop doesn't like the MOTU.
excellent question though, i would like to see this answer as well!
kudos,
-duane
http://www.whentomorrowfails.com
Sony Vaio VGN-FS750P Laptop
1.86GHZ Pentium
3GB ram
120GB internal HDD/1TB external HDD
Windows XP Professional Edition
Sony Vegas Pro, Acid Pro 6.0 (w/ NI Kompakt), DVD Architect Pro 5.0, CD Architect 5.0, Soundforge 8.0, Cinescore 1.0, Fruity Loops Studio 7.0, tons of F/X Packages, and about 60GB of loops & samples.
466MHz Mac PowerPC G4
512MB ram
40GB HDD/1TB external HDD
OSX 10.4.11
MOTU Traveler
DP6
stephentayler
Post by stephentayler »
Try looking in your Applications folder for CueMix FX, ( not the Motu CueMix FX Console)
Hope that helps
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
alex82
Post by alex82 »
Thanks it seems to work now...
I haven't seen that there is also a "CueMix Fx*" folder. I just looked for Motu...there.
But for what is the "CueMix Fx Console"?
jeff sanders
Post by jeff sanders »
alex82 wrote:Hi together
regards alex
right click the dashboard icon chose exit then reopen cuemix. it works for me when for whatever reason ive had it happen to me.
hope that helps
danieltuner
Post by danieltuner »
Hallo, be carefull if is there the upper menu bar of cuemix , if it is there (without mixes window) just clic on fourth item "device" and select the name of your card and the windows come back . When you close the mixes window the cuemix fx is active without window as it is able to change from a card to another one when you have two or more Motu cards on firewire.
