my 10 year old Ghost is starting to scratch on quite a few of the trim pots etc. the faders all seem pretty good still.
I've never done any upkeep to this board, what should I do to get these trims to stop scratching?
thanks
scratchy console
- KarlSutton
scratchy console
MPB 17" 2.66 i7/8GB RAM, OSX 10.6.8, DP 7.24, 828 mkII, Ethno 1 via Ultimate Soundbank, MX4, MSI, Komplete 9, Ivory, Stylus RMX.
for a time:MacPro6,1 3Ghz 8 core 32GB RAM
- BradLyons
- Primary DAW OS: Windows
Re: scratchy console
Call a tech in Nashville (that's where you live, right?) to look at it. That board is internally modular, so you have the ability to pull the circuits up on a channel basis. However, it might be best to have the tech come on-site or take it in. A good cleaning is all it needs, most likely. If that doesn't remove the scratching, try some sort of anti-itch cream!
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
Can something like Caig DeoxIT® be used here, Brad? I know it's great for jack connections...
http://www.caig.com/
monkey man wrote:Can something like Caig DeoxIT® be used here, Brad? I know it's great for jack connections...
Yes. I use Caig DeOxit on everything--jacks, faders, pots--and it's marvelous. Do not use too much... a little goes a long way.
Thank you echohaus; I've heard nothing but good things about it over the years.
