DP4 & Guitar Rig
JGOULD
DP4 & Guitar Rig
Post by JGOULD »
I am new to this, so I apologize in advance if this has been asked already. But, I am having problems getting DP4 and Guitar Rig 1.0 working together. I have Audio Ease VST Wrapper 4.04, also. I can see Guitar Rig in the Insert Menu under the VST Wrapper. But, when I insert GR, no sound comes out. When GR is bypassed, I can hear the guitar track. Am I doing something wrong or won't these 2 things work together??
studiodog
Re: DP4 & Guitar Rig
Post by studiodog »
Doesn't Guitar Rig provide an AU version ?
I'm pretty sure it does and would probably be better than wrapping it.
JGOULD
Post by JGOULD »
Thanks for the info. I am still confused. I am not quite sure what an AU is and how I can implement it. I can use GR as a stand alone unit. When I start DP4, however, GR gets loaded with the VST wrapper. Did I do something wrong? What can I do to fix this??
Thanks,
JIM
studiodog
Post by studiodog »
AU stands for Audio Unit. It is Apple's plugin format.
DP 4 is compatible with MAS and AU plugins when running on it's own.
VST plugins are not usable by DP unless you "wrap" them inside another program (the wrapper).
It seems to me that it would be simpler to use the AU version if you have it. One less thing to cause a problem.
I'm pretty sure that Guitar Rig is a newer program and if you bought it recently and didn't get an AU version they should provide you with an update.
gearboy
Post by gearboy »
Hey there... I'm running GTR RIG as an AU plug-in in DP4.52 and all is working perfectly. I am even using the effects as regular plugs for soft synths and they sound pretty good.
Jeff
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
JGOULD
Post by JGOULD »
I guess my problem is that I am not finding where the AU plug in is or where I can find it. I am new to MAC and I am not sure if I installed something wrong. Should this be coming up in the DP4's plug in list, because it isn't? Will I have to reinstall GR or am I just not finding it??
Thanks for all your help.
Robert
Post by Robert »
I'm having the same problem getting GTR RIG to work in 4.5, Its installed as an AU, the interface opens correctly when adding an instrument track but no sound comes out, I'm using 10.3.7 DP 4.5/MIDI Express XT/2408/G5 1.8 DP / 1.25 G RAM
any help would be greatly appreciated.
dfener
Post by dfener »
I made this mistake at first, too. Do not create an instrument track. Simply create a stereo audio track (L for signal, R for Foot Pedal). Then simply add it as an effect on that audio track, as you would with a reverb, etc. GR should show up on the list of plug-ins.
G5 1.8 Dual|2.5 Gig RAM|828 mkII|DP4.52|BFD|Atmosphere|Crystal|Guitar Rig|
johnschur
Post by johnschur »
Pardon my intruding into the thread, but I think my post is appropriate to the topic:
I can get GR to function by inserting it as an effect in an audio track; the left as audio and the right as Kontrol. Every thing is fine while playing thru, the audio feeds thru both channels, but when I record the track, only the left records audio and the right just records the hum of the Kontrol signal. When I play the track back, I get awful distortion. Also, I can't byass the GR plugin by clicking the Bypass button in the upper right corner of the plug window; the plugin remains active in the signal path regardless of the bypass switch. I've never seen a plugin exhibit this behavior before. Is it just me or has anyone else seen this?
shuld
Post by shuld »
My problem with guitar rig is when I record with the plug in, I cant monitor G-rig with effects. It's just the clean signal. After im done recording it plays with the effects. I want to play with the effects on, so I can get the G-rig vibe. I could do this with Protools le.
DP 7.01, 2 x 2.66 GHz Dual-Core Intel Mac 4 GB ram ,Macbook 2.16 1.5 GB ram, Motu 896HD, Motu Ultralite, Powercore compact, , Reason 4.0, M-box, , MiniMonsta, UAD 2 QUAD, B4 2, Stylus RMX Guitar Rig 4,Battery 3, Universal Audio 6176, UA M-610, 2 Chandler Germanium and Germ Comp, Akg 414, Rode NT 1, Pearlman TM1, Royer 121, Cascade Fatheads 2,Rupert Neve Comp
chrispick
Post by chrispick »
johnschur wrote:I can't byass the GR plugin by clicking the Bypass button in the upper right corner of the plug window; the plugin remains active in the signal path regardless of the bypass switch. I've never seen a plugin exhibit this behavior before. Is it just me or has anyone else seen this?
I can't get it to bypass either. I usually go into Guitar Rig and turn off the individual modules to get it done.
BTW: NI Guitar Rig 2 is available this Monday. Offers new effects, new amps (including some bass amps) and a few more goodies. All the chicks will dig you then, America, I promise.
lestermagneto
using w/o pedal
Post by lestermagneto »
i can just never get it to work without the pedalboard. it sucks having lug that with me all the time as some sort of dongle... when i plug my guit into the 828mk2, all i get is the straight signal until AFTER i record.
pain
chrispick
Post by chrispick »
Upgrade update: Looks like NI has bumped release of Guitar Rig v2 until November. You can step up your GR software from v.1 to v.2 for $120. If you want the new-fangled floor controller as well, be prepared to dish out $450 U.S!
