My wish list:
1. PLAY MODE: Default Auto Stop stop after last soundbite has being played. Now it´s just running forever... can´t even go to the toilet
2. Auto zoom by draging the ruler.. like it used to be in DP 4. Now one has to press
CTR AND drag down pointer on ruler to do that...
3. Ability to auto cross fades when putting 2 soundbites together (like in Wavelab and Samplitude).
4. A visable EDIT LOCK function for soundbites and tracks, so one can see what is done and what is left to fix.
5. Analyzers like geometrics, phase, spectrum meters and a choice of level meters like RMS PPM, VU, Broadcast/Nordic scale and dBfs etc.
6. Waveburner like function! PLEAZE!!!!!! Red Book CD burning with ISRC, EAN/UPC, CD TEXT etc
7. "Logic/Garageband-like" libaries and sounds..
8. Extended and "real" Appleloop compability!
8. Include the Mach 5!!!
9. ONLY One (1) click to play and loop between selected section that doesn´t change when clicking somewhere else with the mouse during playback. FIXED LOOP SELECTION function.
10. Ability to adjust soundbite level like in Wavelab and Samplitude.. That means: just by point and draging down on the soundbite and seeing change in dB.
11. Ability to adjust the mixer size by choice, like the meter bridge is working today.
12. Sequence Editor: Ability to change and move what´s heading the edit functions list in the channel section (left) like Soundbite, Input, Output, Auto, Insert, Take etc. so one doesn´t have to magnify the whole sequence window and tracks just to see or change the TAKE. Quite a lot of work when working with 50 audio tracks!!
13. Cleaner and clearer MIDI screen like in Logic and Cubase arrange windows.
14. Bigger and easier grafics to edit parameters like velocity, CC, program change in the pianorole window. Its all so tiny now!!!
15. "Ez Drummer" just needing ONE channel.. not having to assign an instrument AND MIDI track..
16. FREEZE TRACK into a MONO or STEREO track...not just stereo...
17. A FREEZE TRACK function button (on/off) like in Logic, on every track, not needing another track in the mix... To many mixing channels messes up the view!!
18. compability with OSX 10.3.9 and later
19. A "MOVE ALL TRACKS" or "MOVE TRACK" function for Soundbites without loosing the soundbite position layout. This is the main reason why I use Wavelab when producing preproduced radio shows. It´s real easy and quick.
