Bounce to disk crashing DP6.01!
Ok. So now my excitement over 6.01 working at all has dissipated and i am starting to run into deeper problems a few weeks in.
I had a disastrous experience i hope no one else ever goes through. I had to make last minute changes to a track while clients were present and bouncing to disk crashed many times!
In a professional situation this is the ultimate nightmare! The session ran over time which as we all know is not good.
Also BTD function now takes alot longer in DP6/6.01 compared to 5.13 re loading all the vi's twice it seems. Its a drag. i had to restart dp and trash prefs several times to get it working. it would for a bit, then crash in BTD functions. This kind of instability could be a deal breaker. BTD is one of THE ESSENTIAL functions of a DAW.
Anyone had these kind of issues or has remedies?
Thanks in advance guys, Haydn.
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
Re: Bounce to disk crashing DP6.01!
I have had the same issue - crashing after trying to bounce vocal tracks that have Auto Tune (AU). regretably, i don't have a solution. just chiming in
- Mr_Clifford
Well you can always record your mix to a stereo track rather than using BTD. Real time, but very safe, and you check the mix as it goes down.
- kassonica
+1Mr_Clifford wrote:Well you can always record your mix to a stereo track rather than using BTD. Real time, but very safe, and you check the mix as it goes down.
It really is the best work around, plus the client can check the mix as well.
I get crash when I BTD without freezing VIs. Especially with Kotakt3 and Kontakt playper..
Does anyone have the same problem?
DP 6.01, Mbox 2 Pro. Mac pro 8 core. Lots of VIs.
Yeah. But you have to BTD function afterwards anyway. Yes?Mr_Clifford wrote:Well you can always record your mix to a stereo track rather than using BTD. Real time, but very safe, and you check the mix as it goes down.
DAW:DP8.05
VI's/Plug-ins:
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
Once your mix is recorded to a stereo track it can simply be exported, no need for a BTD.
kind regards
Stephen
kind regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
This is true-- and it is a lot easier if you're already working in native aif or wav. In fact, a formal soundbite export isn't even necessary at that point. The file resides in the project's Audio folder and can be imported by any other app (that supports wav or aif) directly from the DP Audio folder.stephentayler wrote:Once your mix is recorded to a stereo track it can simply be exported, no need for a BTD.
kind regards
Stephen
As in the suggestions above, we have been recording our mixes to audio tracks for years now - however when the client is elsewhere and we need to send a Quicktime or MPG, so they can see pictures and sound - then we need to BTD, to the Quicktime format. And this is when it can hang. Specifically when using Play or Kontakt, as after bouncing, it reloads the sounds, which is when the crash happens. And I've just got Omnisphere, and that makes this problem much worse - for some reason Omnisphere loads in a completely different Multi - or DP hangs completely. I'm pretty sure it's not an Omnisphere problem, as the NI VIs also reload their sounds after bouncing - so it must be DP6.01?
Macbook Pro, DP11.1
- timriley
Make sure you dont have any tracks record armed before bouncing. I seem to remember this causing issues in the past...... just a thought!
Mac Pro Quad XEON/2.8Ghz/12GB RAM
Macbook Pro Core Duo/2.16Ghz/2GB RAM
OSX 10.6.8/DP7.22
OSX 10.6.8/DP7.22
- Shooshie
You can still bounce to AIFF, then load it into Quicktime Pro. It's under $40, and is an incredible bargain.celestial wrote:As in the suggestions above, we have been recording our mixes to audio tracks for years now - however when the client is elsewhere and we need to send a Quicktime or MPG, so they can see pictures and sound - then we need to BTD, to the Quicktime format.
Hi,
Does anybody aim at applying an effect ( like reverb or echo ) and get some post roll...?
i put some kind of 45 000 and get no length..?
