MOTU Universal Audio Install- OSX- 1.4.9
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Re: MOTU Universal Audio Install- OSX- 1.4.9
Thanks for the heads up!
I assume that this is an Intel only update?
I can see where it might be read that way, and the bug fixes may be primarily for those machines, but I think it can be installed on any machine running at least 10.4. Not sure if the CueMix FX is an update, or not-- the version from this update is 1.02. Anyway, it installed fine on my PPC iMac, although I don't currently have it hooked up to my 828mkII to test it.
I have it running fine on my 2x2.5 PPC G5 and my 828mkII.
PowerMac G5 Dual 2.5 / 4.5 GB RAM
OSX.4.11 DP 5.13
OSX.4.11 DP 5.13
Any changelog around ? Or reports ?
Klaus
Klaus
Found a fix : Channel names editing doesn't crash anymore, thank you MotU !
( 896mk3 )
Klaus
( 896mk3 )
Klaus
- Dwetmaster
About Time!!!Klaus wrote:Found a fix : Channel names editing doesn't crash anymore, thank you MotU !
( 896mk3 )
Klaus
That alone will have me do the update...
Also rearranging channel order in CueNix FX would be nice
Klaus
Klaus
- daniel.sneed
Punch in thru footswitch won't work any more on my 828mk1 with 1.4.9.
I've much use of this feature : either to record in studio (set to send [3]) or toggle play-pause on stage (set to send [Spacebar]).
I had to reverse to 1.4.8 and all is fine again.
dAn Shakin' all over!
- williamm
Re: MOTU 1.4.9- doesn't fix audio dropouts for Intel MBP
FireWire 1.4.9 didn't fix the audio dropouts I've been suffering from with 828 Classic, Intel MacBook Pro, and AudioDesk 2.11. By the way, how can I search this forum for references to "1.4.9"? The search engine says it's too common, even if I type it in quotes.
Regards,
Regards,
Mark Williamsen
Lindenwood Studios
Mac G4 Cube, OSX 10.2.8,
MOTU 828, Driver 1.2.5,
AudioDesk 2.04
Lindenwood Studios
AudioDesk 2.04
@williamm-
still getting dropouts here too, but on an ultralite/imac 2.8 gHz/any audio app. unable to contact tech support for two weeks, always busy, no response via techlink. looks like time to get rid of the motu and go with something else. lame.
Channel names now get saved / recalled with the configuration !
Nice improvement, thank you MotU !
Klaus
Klaus
- jeff sanders
double clicking the monitor level knob in cuemix still turns the volume full blast. when i first bought my 828mk3 double clicking the monitor level knob in cuemix would turn the volume completely off. after an earlier update i noticed it somehow reversed function so that double clicking maxes the volume setting, so it remains. poo i declare.
Now my Ultralite mk3 is recognized in MIDI Devices in Audio MIDI Setup.
It wasn't in 1.4.8. Huge bug fix.
Jamie
Jamie
