I'm going to put this in the first post and also in the version history so I don't have to keep repeating itTimeline wrote:That looks much better to me Aplidood. Which image file mods the green VU lev indicators from blue and can you do it to all the VU's?c
Special note on metering
All the meters (with the exception of the small track list meter) are attached to the color settings in the Default Style XML document. The grahpics files for the way the meters used to look (green to yellow) are still in the images folder...all over the place as a matter of fact. Somehow MOTU decided to override those files and use a single color defined by the XML doucument. I haven't figured out a way to detach the two, and there may not be without getting into DP's binary code. I'm not really willing to dig around in there. So for now the only meters we really have any control over are the Tracks Overview level meter. Another problem is that changing the meter frame color works everywhere except the mixer. So I've just left it alone for now.
