The free VI's/plugs list.
Gee, thank you Timriley. The TAL plugs are slowly being ported over to AU, and this seems to have seen this new one immediately available in that format.
Nice one mate. Thank you again.
I went ahead and consolidated and checked everything mentioned in the list, as well as adding a few things and cleaning up links.
http://www.tritonedigital.com/
ColorTone Free and PhaseTone
http://www.izotope.com/
iZotope Vinyl
http://plasq.com/musolomo
Musolomo
http://www.solid-state-logic.com/store/
LMC-1 Plug-In FREE
http://www.alphakanal.de/snipsnap/space/Automat
Automat
http://www.greenoak.com/crystal/
Crystal
http://www.digitalfishphones.com/main.p ... &subItem=5
Fish Fillets
http://www.betabugsaudio.com/plugs.php
Monsta Chorus
http://www.lowcoders.net/kd.html
King Dubby
http://www.luxonix.com/home/en/products.html?id=lfx1310
Luxonix LFX-1310
http://www.smartelectronix.com/
Various Smart Electronics
http://musicunfolding.com/xtrem.html
Xtrem
http://musicunfolding.com/muxeq.html
X-EQ
http://www.u-he.com/TripleCheese/index.html
Triple Cheese
http://www.camelaudio.com/camelcrusher.php
Camel Crusher
http://www.niallmoody.com/ndcplugs/harmonical.htm
http://www.niallmoody.com/ndcplugs/particlefountain.htm
http://www.niallmoody.com/ndcplugs/buffsynth.htm
http://www.niallmoody.com/ndcplugs/buffsynth2.htm
http://www.niallmoody.com/ndcplugs/buffsynthalpha.htm
http://www.niallmoody.com/ndcplugs/sinesynth.htm
http://www.niallmoody.com/ndcplugs/feedbackything.htm
http://www.niallmoody.com/ndcplugs/ampimposer.htm
NDC plugs
http://www.asylumstudioproductions.com/plugins.cgi
PAEIN
http://www.vertexdsp.com/products_multi ... rfree.html
MultiInspector
http://essej.net/sooperlooper/
Super Looper
http://bigtick.pastnotecut.org/index.ph ... &pcode=120
Ticky Clav
http://www.keytosound.com/?desired_section=remedy
Remedy
http://audio.lernvall.com/
LA Convolver
http://www.yellowtools.com/
Independence Free
http://www.quikquak.com/Prod_UpStereo.html
Up Stereo
http://www.voxengo.com/product/overtonegeq/
Overtone GEQ
http://www.apulsoft.ch/freeports/
Various nice freebies
http://www.dontcrack.com/freeware/audio ... oads/Flux/
BitterSweet
Flux
http://www.dontcrack.com/freeware/downl ... ntSampler/#
InstaSampler
http://www.dontcrack.com/freeware/downl ... mple-Gate/#
Zimple Gate
http://www.kresearch.com/download_freeseries.html
KR-Reverb
http://www.airwindows.com/
Various Free plugins
iZotope Vinyl
Musolomo
LMC-1 Plug-In FREE
Automat
Crystal
Fish Fillets
Monsta Chorus
King Dubby
Luxonix LFX-1310
Xtrem
X-EQ
Triple Cheese
Camel Crusher
NDC plugs
PAEIN
MultiInspector
Super Looper
Ticky Clav
Remedy
LA Convolver
Independence Free
Up Stereo
Overtone GEQ
BitterSweet
Flux
InstaSampler
Zimple Gate
KR-Reverb
limited time offering:
http://www.bias-inc.com/special/freeMPS ... er=mixline
gate ex from master perfection sweet
click the link at the bottom of the page, or go for one of the sale packages they advertise. seems decent.
Re: The free VI's/plugs list.
New build, new skin. Get it while it's hot:
http://www.alphakanal.de:4356/articles/ ... utomat-1-0
P.S.
This is the setup that works for me:
Macintosh HD>Library>Audio>Presets>alphkanal>Automat1 Folder>Presets>.aupreset(s)
User>Library>Audio>Plugins>Components>Automat1.component
User>Library>Audio>Presets>alphakanal>Automat1 Folder>samples AND tuning folders
As far as I can tell, the samples need to be .aif files
P.S.
- daniel.sneed
Great ! I love Automat.cuttime wrote:New build, new skin. Get it while it's hot
I use it to add *spice* on many projects since Buzzer days.
Welcome to the 1rst non-beta one.
dAn Shakin' all over!
I just installed Automat 1.0 and everything goes to your User folders rather than to the Global ones when you launch the install shell script. On OS X 10.4.11, DP 5.13 doesn't show the presets in the mini-menu list, although it does show the samples and tunings in the plug-in's pop-up menus. If you move everything to the Global folder, DP sees the presets but it doesn't see the samples and tunings, so some of the presets won't work.
You have to put the presets in the Global folder and the samples and tunings in the User folder to get this to work properly. I've no idea why alphakanal does it like this. Just a heads-up for those who may be having problems.
Global path for presets:
<Boot HD>/Library/Audio/Presets/alphakanal/Automat1
User path for samples and tunings:
<User short name>/Library/Audio/Presets/alphakanal/Automat1
Note the lower-case "a" for "alphakanal."
Kind regards.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
– ideation –
Thank you for sharing that critical info, Davo.
Stiwi's been on our board before, and he did attempt to clarify this stuff. Here's hoping he consolidates/simplifies things further with subsequent releases; this makes no sense to me.
Speak of the Devil - Automat 1.01 AU UB has been posted:
http://www.dontcrack.com/freeware/downl ... e/Automat/
The previous (1.0) version has been removed from this site, which is interesting.
http://www.soundhack.com/
Just released: Delay Trio
The three plugins are +delay (classic delay effects), +pitchdelay, (essentially the same plugin with controls oriented toward pitch shifting), and finally +bubbler (a granular delay in which grains are pulled from the delay line with randomized start time, delay time and pitch shift value).
- kassonica
Much thanks for these Great plugs for textures and thinking outside the square.stickwolf wrote:http://www.soundhack.com/
- timriley
Just found this free AudioUnits UB plugin from Reign Design called 1-time.. Tape Saturation plugin that sounds quite interesting to my ears... Different to the free Massey plugin..... Apparently especially good used on kicks and basses!
http://www.reign-pro.com/
Mac Pro Quad XEON/2.8Ghz/12GB RAM
Macbook Pro Core Duo/2.16Ghz/2GB RAM
OSX 10.6.8/DP7.22
OSX 10.6.8/DP7.22
- timriley
Be very careful with some of the other effect plugin demos from Reign Design...... They have some serious issues on my system such as loud bursts of an indescribable noise and according to some other forums i've read, im not alone! The Red Tape and Q Box were the worst culprits.... Not quite ready for human consumption i think!!timriley wrote:Just found this free AudioUnits UB plugin from Reign Design called 1-time.. Tape Saturation plugin that sounds quite interesting to my ears... Different to the free Massey plugin..... Apparently especially good used on kicks and basses!
OSX 10.6.8/DP7.22
OSX 10.6.8/DP7.22
