Going from BWAV files back to SD2 increases DP6 stability
ghobish
Post by ghobish »
Wanting to be part of the modern world, I set BWAV as the default file format in DP6 and started editing a new 88.2K tracking session (about 20 tracks, actually recorded at another studio in ProTools) in DP6. Crashes everywhere. Delete a marker, get a crash. Select a group of tracks for editing, get a crash. Look sideways, get a crash. (No templates, no plugs, tested with all third party plugs disabled, etc).
After opening up a ticket, attaching a crash report and the session file, appending the ticket with four more crash reports and not getting a response for a week, I thought I'd try redoing the session after converting the ProTools BWAV files into SD2 (using Barbabatch). Edited 5 takes of that song and then 2 more songs without a single crash.
I'm back on SD2 for the time being.
Maybe there's something specific about BWAV files recorded in ProTools that's the problem?
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
wurliuchi
Post by wurliuchi »
Thanks for that. Very interesting. I'm going to try a project with SD2 and see if that stops the crashing while editing in the S.E.
DP 6.03 • MacPro 2x3 Ghz Dual-Core Intel Xeon • 9 GB RAM • 10.5.7 • Prayers
Post by Shooshie »
Now what would be interesting is to find out whether conversion back into BWAV might work without a crash. In other words, could the originals have been corrupted in some way that Barbabatch fixes?
ghobish
Post by ghobish »
Shooshie wrote:Now what would be interesting is to find out whether conversion back into BWAV might work without a crash. In other words, could the originals have been corrupted in some way that Barbabatch fixes?
Yes, that is the interesting question. (Barbabatch, by the way, is getting quite long in the tooth these days...)
Maybe I'll try a session where I take the ProTools WAV files, convert them into WAV files (basically doing a batch "Save As.." operation) and see what happens.
If that works, I'll try setting DP to use WAV files but have it automatically convert everything on import. Maybe we're getting somewhere.
Gary Hobish
San Francisco, Ca
martian
Post by martian »
aha! I was doing convert everything on import since day 1 ( I was the epic swimmer against crash on save )
any old 5.XX projects I was using the "load" featre ( they DID fix that in 6! )
I believe I have had an entire 5 or 6 crashes in the last 3 weeks...
also I believe MOTU thinks you will operate in this manner... I mean it can't be unaware that it has the worlds flakiest "pro" file formats and with the price of a terrabyte you are only asking to be shat on if you dont make regular back ups - or copies on import
if you look in the manual it actually explains how it writes each region into the audio file - which explains how things go pear shaped big time...
http://www.fork-media.com
mhschmieder
Post by mhschmieder »
Thanks for letting us know.
You might want to change the topic title so it's clearer though. I almost didn't bother reading it because it says WAVE not BWF or BROADCAST WAVE.
I haven't started a new project in DP6 yet, and was unsuccessful in converting old ones to BWF, so maybe it's just as well. My next attempt will probably be more direct, using the Soundbites Window's mini-menu.
ghobish
Post by ghobish »
mhschmieder wrote:You might want to change the topic title so it's clearer though. I almost didn't bother reading it because it says WAVE not BWF or BROADCAST WAVE.
Thanks for the heads up, though since DP6 only handles BWAV (and that's also what ProTools was set to) it's kind of a moot point.
Gary Hobish
San Francisco, Ca
