2408 mk3 is not seen in MOTU Audio setup
I had a Sonnet FW card. I've taken it out. My connection issues are intermittent so it's hard to draw conclusions in a timely fashion. I'll let you know what happens.
Aramis. I'm not familiar with that utility - or what to do with it if I had it. I have an original 3GHz 8-core. ...your sig says you have an "Octo". Is that the same thing?
OCTO , yes it is ! Now , if you got the most recent Mac Pro .
That utility does not exist .
It was on the previous Mac Pro .
I think the tool was to adjust the bandwidth of the PCie slots .
I am very curious about your problems !!!
Aramis
Aramis
dix wrote:I had a Sonnet FW card. I've taken it out. My connection issues are intermittent so it's hard to draw conclusions in a timely fashion. I'll let you know what happens.
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
Shoot. I remembered that I need to have that FW card in there for the time being, so it's back in now until I can get around to getting another UAD-1 card to replace this piece-o-s***t LiquidMix. Man, what a headache that thing is! ...but I digress.
Thanks for your interest Aramis. I have an older 8-core, but I don't see that utility nor would I know what to do with it if I did. Are you saying the 2408 should get more bandwidth or less?
I found this ,
http://docs.info.apple.com/article.html?artnum=304122
The Expansion Slot Utility, located in /System/Library/Core Services
Aramis
Maybe !!!!!
Aramis
Maybe !!!!!
dix wrote:Shoot. I remembered that I need to have that FW card in there for the time being, so it's back in now until I can get around to getting another UAD-1 card to replace this piece-o-s***t LiquidMix. Man, what a headache that thing is! ...but I digress.
Hey Aramis,I found this ,
Thanks for chiming in on this thread. I did read the article and I have to admit it's a little over my head. I don't know if I have the utility or not but I wouldn't know what to do with it if I did have it. I think Dix and I are trying to figure out by a process of elimination what is causing the communication loss between the computer and the PCIe card. Without that communication everything comes to a stand still.
scooter
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
The card that you have put in your computer is a pcie card .
You have 3 or 4 pcie slots in your computer
If you have the old macpro , all your cards do not works at full speed
That tool will show you if your card is installed in a 1x 2x 4x or 16 x slot .
The reason I am showing that to you is to help you determine if your mac does see your pcie card ok and at what speed it is dealing with it .
I read your steps and I do believe you have a pcie problem both of you .
Aramis
Aramis
scooter wrote:Hey Aramis,I found this ,
scooter
Cool.
I'm using my old G5 at the moment with the older PCIx card in it, so that I can work.
I think any info I can get from the computer telling me what it knows about the PCIe card at this point would be a help. So I'll check that out when I get back to it.
scooter
scooter
Hey Scooter-- I explored the utility Aramis mentioned last year. I learned that the PCIe-424 is a 1x card, so setting it to 2x or higher will have no effect. I was hoping it would myself...scooter wrote:Cool.
scooter
However, trying a different slot and making sure it's firmly seated is a good thing to check in any case.
Basically, if you've sent the card to MOTU once for a replacement, the ball is in MOTU's court to work with you until it's fixed. If they have reason to believe it's not the card, then they should work with you by going through every possible setting with DP, Audio MIDI, Bundles, and the PCI Console to get it to work.
One other thing to check as a litmus test would be to set up a project in Garage Band. If it works in GB, then it's a good sign that it's not the card or the driver. It's probably DP. I'd then uninstall DP entirely, reinstall the version of DP you have on disc, then install each update from there until you get to the version you want to use, like 5.13. If you are using DP6 then it's all from disc since there's only one version of DP6.
If there is a question about OSX, I would strongly recommend doing the COMBO Update of the version of OSX you are using now. Look for an OPTIONS menu in the lower middle part of the COMBO UPDATE installer. If there is not an OPTIONS button, proceed with the installation with confidence.
If there IS an OPTIONS button, click it and choose "Archive and Install"-- then proceed with confidence.
That is my point . What does your computer sees about your pcie bus .
Exactly
Aramis
Exactly
Aramis
scooter wrote:Cool.
scooter
- ghobish
(sorry, accidental double post- see below)
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
San Francisco, Ca
- ghobish
I had severe driver problems at one point a few years ago, and this advice from MOTU Tech Support helped:scooter wrote:Here's what I've done:
Switched slots for the PCIe card in the mac itself.
New 2408 mk3
New audiowire cord
Trashed prefs.
Trashed the other stuff in Frodo's list
Uninstalled the audio drivers.
Reinstalled a new one.
Unhooked the micorclock.
Unhooked the 24 i/o.
Don't know what else I can do.
scooter
1. Go to System > Library > Extensions and drag MOTU PCI AUDIO to the trash.
2. Go to Applications and drag all MOTU Consoles to the Trash. Empty the trash.
3. Repair Disk Permissions, then redownload the latest PCI drivers and reinstall. Reboot the computer.
Apparently sometimes the uninstall script doesn't completely uninstall.
Good luck!
Gary
Gary Hobish
San Francisco, Ca
San Francisco, Ca
That's what they all say regardless of flavor of PCI.LWD wrote:Scooter,
I know that 424 represents PCIexpress. By why at the title part of your screen shot does it just say PCI? Perhaps you installed the pci-x version and not the express, or is that just the OS and the way it's displaying the driver sound setup window?
Okay MOTUs theory that this issue could be a compatibility issue with my FW turns out to be incorrect. I pulled the FW card and still I'm having the same "connectivity crashes" - had one today at VERY bad time. I'm going to have MOTU send me another card I suppose.
