What's the setting so that when you double-click a selection in the track window (either MIDI or audio), it will switch to the MIDI or sequence editor right inside the central consoldated window (instead of opening up a new pane)?
I had it setup this way for DP5.13, but when I trashed all my pref files when installing DP6, everything reverted back, so now double-clicking always opens a new pane in the consoldated window instead of simply switching.
I'm working with a monitor/TV with fairly low vertical resolution (widescreen, not great resolution), so I can't afford to have two central panes open at the same time, but I don't mind the central pane switching. I'm posstive I had it setup this way in DP5.13... but I may have to just use a non-consolidated window for all my editing, which could be a pain.
What's the setting to...
- PrimeMover
Mac Pro (Quad 2GHz) | 7GB RAM | Mac OS 10.5.4 (Leopard)
DP6 & DP 5.13 | Kontakt 3 | EWQLSO Gold XP
MOTU 8pre | Alesis QS8.1 Synthesizer
DP6 crashes with ProVerb
- PrimeMover
That's not what I think I'm after. I think the settings your refering to simply toggel whether an edit window opens in the consoldated window or in a separate window. What I'm talking about is still having the edit window open in the consoldated window, but have it replace the current pane (tracks window) instead of opening up a new pane below it. I could be mistaken, there could have been an option that I missed... but I looked through it no fewer than 5 times, and I didn't see anything like that, and I remember having it setup to work like that in DP5. Tell me if I'm wrong here.
- Shooshie
On the same page that Frodo mentioned there is a "Max number of panes in the CW" which should do the trick. Set it for 2, and then it will start replacing panes instead of opening new ones. Unless it's busted.
