Send Outs on the 828 MK3
majdid
Post by majdid »
How to use the two Send outs on the 828 MK3? is it possible to use them from Cubase or is it assignable on the CueMix software only?
i would like to use my external Reverb processor with the 828. from what i understand, the send on the rear of the unit are corresponding to the front mic inputs, and any rear input can be used as an fx return. i would like to send some of the 1-8 input signal to the two sends outs rather than using the two front mic/instrument inputs. it that possible? where can i do the necessary routing?
thanks
Pappy725
Post by Pappy725 »
On my 828mkII, the sends are only for the two mic/guitar inputs on the front panel. And yes, you have to use one of the 8 line in's on the back to return the signal to your computer.
Pap
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
majdid
Post by majdid »
any other way to aux send/return a signal from this little baby? using maybe the main analog/out/ins?
CSprague
Post by CSprague »
I just ran a short test, my external sound processor lexicon MPX 550 uses SPDIF for digital, I tied the SPDIF from the MK3 to it and am able to use the different effects in the mix.
majdid
Post by majdid »
i checked, the MPX 550 is having coaxial RCA connectors for S/PDIF, unfortunately (or fortunately), my reverb unit is a Behringer V-Verb Pro 2496, which is having XLR AES/EBU and optical (toslink) S/PDIF...
im wondering if there is any cables that will hook the two units, without requiring the use of some kind of converter like the behringer ultramatch pro...???
CSprague
Post by CSprague »
The Adats on the mk3 are convertable through the audio console to Toslinks.
majdid
Post by majdid »
i dont have any mixing console. i guess i will stick to analog connections... thanks
mordonic
Post by mordonic »
Such a shame the Auxillaries aren't truly such.
AriSuu
Post by AriSuu »
majdid wrote:i checked, the MPX 550 is having coaxial RCA connectors for S/PDIF, unfortunately (or fortunately), my reverb unit is a Behringer V-Verb Pro 2496, which is having XLR AES/EBU and optical (toslink) S/PDIF...
I just built a cable like this:
http://tcsupport.custhelp.com/cgi-bin/t ... _topview=1
I used it to connect my behringer rev2496 aes/ebu input/output to motu 828 (mk ii) spdif coax rca connectors. Seems to work ok.
Maybe there are also ready-made converter cables, but I couldn't find any however.
majdid
Post by majdid »
very interesting, thanks for sharing the info.. anyway, i guess i will stick to analog connections for now, planning to get two additional pre-amps to add 16 ins and make some use of the lightpipe connexions..
probably something like the presonus stuff or the motu 8pre ...
do you use both reverb engines on the r-verb?are u able to do so using the aesebu/spdif cable? this thing sounds really great btw
adammazza
Post by adammazza »
I see mention of using the spdif connections as send/returns as for external effects. Can tha analog in/outs be used the same way? I have a BBE Sonic Maximizer I'd like to use. I'd use just one channel.
Adam
Pappy725
Post by Pappy725 »
yes, but it might introduce some latency to the returned signal. DA/AD conversions slowing things down a bit.
Pap
adammazza
Post by adammazza »
Thanks. I've read the tech note on MOTU's site, about patching in external effects, but I'm still having issues. I am running Out8 into the input of my BBE and running the BBE out into IN8. What would be the proper way to setup the routing for this in CueMixFx? Preferably I'd like the option of either recording with this effect or not (just being able to play back through my monitors with it). Would I basically set up 2 different mixes?
Adam
Pappy725
Post by Pappy725 »
Do you see any indication of signal getting out to your BBE? You may need to check in CueMix on the output of that channel. I can set mine to +4 or -10 in CueMix individually on each channel. Also make sure which bus CueMix is using to output your affected signal.
Hope some of this helps.
Pap
majdid
Post by majdid »
i'm doing this to send some of the signal to my reverb processor, using OUT7-8/IN7-8. however in your case, you need to configure the BBE as an insert and not aux send, so that you get the full signal processed.
latency is not an issue for me as im using direct monitoring in cubase, that let me keep the flexibility of choosing whatever audio chanels i want to send some dry signal to... however, trying to get my external synths to get the same processing and send some of their dry signal to be processed by the verb processor introduced some latency when direct monitoring is disabled..
