828mk3 installation problem
The installation freezes up during install after the hardware device is detected and the couple of times it has installed after waiting ages it still doesnt detect the 828 even though its still plugged in after the install?
Im using winxp sp2 with an onboard firewire card on my laptop.
hi,
microsoft does not make fw chips...
it uses rico chipset (which is ••••)
shutdown pc.
connect and turn on the interfaces.
then start the pc.
try again.
maybe this helps.
additional info:
http://forum.sewelldirect.com/expressca ... 82.15.html
so if the trick with boot with connected interface does not help you can only try with your (pc using the latest bios) + a firewirecard and hope that it works...
shutdown pc.
then start the pc.
try again.
maybe this helps.
additional info:
