Can't Get Mach five to work in Logic Studio
I'm trying to get Mach 5 to work in logic,it see's it and I can play it on my controller,but if I record the MIDI it will not play back,any knowledge on this,would be very greatfull
Just testing this thing out
Hi all,
I seem to have exactly the same problem. I'm running Logic Pro 8 on a Dual 2.5 GHz PowerPC G5 with 4 GB RAM running OS10.4.10 with an Alesis iO/14 Firewire Soundcard.
When I try to record anything with MachFive the sounds are triggered during recording and a MIDI part is created. When I try to play it back, however, no sounds come out. A MIDI signal is certainly going somewhere as the "keyboard" graphic within MachFive lights up as if something is being triggered, but no noise comes out.
All my other AU instruments are working fine
Hope someone can help!!!!
Bugsy
Bugsy
Versions... need versions..Akai96 wrote:No help?Ok I see where this is going
of Mach5
logic
OS
etc..
If you hadn't updated Logic just yet... do so. 100+ fixes in there..
/B
