Can't Get Mach five to work in Logic Studio
Akai96
Post by Akai96 »
I'm trying to get Mach 5 to work in logic,it see's it and I can play it on my controller,but if I record the MIDI it will not play back,any knowledge on this,would be very greatfull :?
Just testing this thing out
bugsy
Post by bugsy »
Hi all,
I seem to have exactly the same problem. I'm running Logic Pro 8 on a Dual 2.5 GHz PowerPC G5 with 4 GB RAM running OS10.4.10 with an Alesis iO/14 Firewire Soundcard.
When I try to record anything with MachFive the sounds are triggered during recording and a MIDI part is created. When I try to play it back, however, no sounds come out. A MIDI signal is certainly going somewhere as the "keyboard" graphic within MachFive lights up as if something is being triggered, but no noise comes out.
All my other AU instruments are working fine
Hope someone can help!!!!
Bugsy
Akai96
Post by Akai96 »
No help?Ok I see where this is going :lol:
carrythebanner
Post by carrythebanner »
The last version of MachFive v1 is pretty old at this point – I wouldn't be surprised if it exhibits some issues in hosts which are much newer. I don't think MachFive v2 has the problem you're describing.
bjornln
Post by bjornln »
Akai96 wrote:No help?Ok I see where this is going :lol:
Versions... need versions..
of Mach5
logic
OS
etc..
If you hadn't updated Logic just yet... do so. 100+ fixes in there..
/B
Akai96
Post by Akai96 »
of Mach5
logic
OS
etc..
I'm Using Logic Studio 8,and Mach 5 1.2.3,G5 Dual 2.0. Still in 10.4.11
ttauri
Post by ttauri »
Yeah, Logic 8 broke compatibility with M5 version 1... :cry:
v. 2 works... Though lots of issues loading my v.1 patches--typically all samples are set to one-shot. For my projects that have a lot of v.1 stuff, I've been staying in Logic 7...
Peece,
T. Tauri
