Hey Tele, first of all thanks.
Since I have no experience with logic 7, I highly recommend that you contact motu tech support...a "techlink
1º Thanks for your advise,I did it but no response from 2 days.
First, have you been able to get ANY MIDI into logic through the ultralite?
2º No problem sometime I connect my miniKorg, and works perfectly
Second...if the m's are flashing, that means MIDI is being sent to the ultralite...do you know what this MIDI is? If not, you may want to download a free MIDI monitor from
www.snoize.com
3º amusing,I was impress, thanks for the program and the information.The MIDI monitor says that the MIDI is sent by the faderport(control surface), says something like ZERO;ZERO;ZERO
I went to the faderport configuration, there is a control how says return to zero, I tried to turn it off but nothing, the problem continuos.
make sure all is correct in the audio MIDI setup ... and in the "click and port" layer of the environment (I"m not sure this exists in logic 7 - if it does exist...check to see it's correct).
Exist, but I expend about 1 hour because my logic is in Spanish, im so stupid(Click y puertos). I did everithing but nothing
I sended a message to faderport support, no response so Im going to wait.
Please this is my e-mail addres in case you need something from Spain.
zop00@hotmail.com, I apreciate all your help, thanks again
