DP Crashes during save
yeah - I thought of that too - or non "apple" ram -
I replaced the "non" apple and still the problems...
i put the non apple back in and now have 5 gig ( should update sig )
As 4 gig is the max DP can access - hopefully isn't RAM
it's weird it's not ALL projects...
Not even all projects from same template - ( which has been recreated to eliminate as source )
but once a project starts to cos - that's it - it just keeps on doing it....
I thought I had it sussed - with copy/paste/duplicate save solution - and if it comes back just do that again - but it seems not..
It could be related to firewires going to sleep on bus as a combining factor - but then I ejected all drives and it made no difference - was still COS -
Not sure it's USB MIDI as it happened on my Imac which has got 828 - so no other MIDI/ usb
it's not wacom tablet -many users vouch for them ( unless it's wacom tablet and long projects? )
well if Kazuya and arion don't report back with probs I may have a real close look at uniinstalling and trying with out wacom installed? hope my rsi can take it!!!
http://www.fork-media.com
I once hoped that 4,5 GB of RAM is just enough...
Right now we are working on a 1 hour project. Today about 10 hours. 1 crash when i tried to hear a part of a soundbite right after import. That‘s O.K. for a day like this. Still got my iLoks and the Hub disconnected and went back to DP 5.01 (just for this one because i could not open it in 5.12., but that‘s another task)
It‘s really like fighting against a computervirus. once you think that you have fixed the problem, it crashes again. you fix it again, it works for a time and suddenly it crashes again...
These computers definitely have a soul and they know when it hurts most.
I have to finish 2 projects this weekend as we go to mastering on monday. hopefully i don‘t have to report probs.
Good LUCK FOR ALL OF US
DP 9.12 // MacPro 8-Core 2,26 // OSX 10.11.6 // 32 GB RAM // UAD-2 // PSP // Sonnox // 828 MK-II // Altiverb 6 // MachFive 2 // iZotope // ...
Excuse my bad english. I´m just a german.
I'll inform you. Ist's unfortunatly now impossible for me to remove my iloks becouse we do MIDI work all the time.kazuya wrote:hi arion,
please keep me up to date with the iLok stuff.
Would be "funny" if DP works fine without the iLoks of the Motu stuff.
Whenever i have the choice to use challenge/response for activation i prefer it.
Hope it works for you
... o.k., maybe we have to sell our MachFive and MSI... and my SonyPlugIn and...and...and...
Wow - a new info , since I work exlusively MIDI ( not audio at all ) I had no crashes..
USB
Mixed the hole Weekend, over 20 hours heavy DP use and everything‘s just fine.
Today i had 1 COS and i thought: ••••, the Problem is back and the USB thing is not the sollution...
Then i remembered that i used a usb stick 1 hour ago and left it mounted.
So the COS again with USB...
mmmhhhhhhh, i can the clearly now, usb is gone
Have a good night, i have to sleep now, in 5 hours i have to go to the masteringstudio...
Next week i‘ll make some usb cos ilok tests !!!
hey dude! that's good news... there are definite things that I find cause it - but I haven't discovered them all.
I thought I had solved it- and on the whole it is MUCH better
I found if I let a drive go to sleep whilst mounted then it could crash on save...
Once projects COS they COS no matter what - you need to repair them - ie make new projects and duplicate audio - ( well it's just a theory - or maybe a ritual to go with my prayers...) and it usually works for a day or 2....
Perhaps you could still report the issue to MOTU - they need to know from a few sources!
cheers
mart
cheers
mart
- David Helpling
This happens to me all of the time on LONG projects with MANY sound bites...I often have to "Save A Copy As". These are always around 1.5 to 2 hours long. After doing so many projects in DP for so many years I feel like DP has issues with long projects (not high track counts though). It tries for a second or two to save the file then DP quits...once that happens it seems to not be able to save the file at all without quiting on me...like it reached a wall or something?
David Helpling - Composer/Producer
MacPro QuadCore 3GHz, Leopard/DP6.01/6 gigs RAM/Apogee Symphony and Hardware/MachFive2/WAVES/NI/URS/Spectrasonics/Analog Outboard
www.dhmmusicdesign.com
hi David - nice work btw - I checked your ambient stuff a month or so ago... I do a lot of film sound design and I'm totally into ambient sounds - I'm more manic than mystical tho! I have made quite a few synth sounds from airconditions etc - trippy and errr cool!
For sure this is a length of project thing! unfortunately as a sound designer I am usually am working on at least 20 minutes ( 1 reel) or occasionally a 90 minute cut - my template is around 50 channels (18 stereo - 32 mono - 4 verb returns and 5 surround submasters)
I don't think it has ever happened to me on a short project!
the weird thing is it can be fine for days at a time - then crashing every 20 mins... ( to add to the weirdness - it's just one project - other projects fine!!!)
Now I do the ritual if it COS more than twice in an hour and that mostly gets me going again for a day or 2.
I have filled a tech report with motu
can you fill one in and be ignored too!
who knows they may fix this in DP 6 if they know more than one has this issue - that would make me very happy as apart from this DP is great!!
cheers!
cheers!
- David Helpling
Thanks for the compliments on my work...I would love to hear some of your original sound design work and mixes for sure. I too often have one project that seems "Corrupt" in this manner. usually consolidating or bouncing some of the dialog tracks that have so many soundbites, fades and volume-mapping and "Save A Copy As" to a new file has helped but it always comes back. It seems that once this happens the file has trouble saving from then on. I am 100% convinced that this is a length/size issue - I NEVER have this problem on short-form cues and spots.
think there is one online - 2nd time around and empty words -
I seem to be a bit slack in finishing my own stuff off really - waste too much time on internet - in front of DP all day for work..... ( lots of work stuff online
- this is my own little bit.. all made from orphans I found at work...
www.myspace.com/bastardsounds
