will an upgrade (5.13) install leave a 4.61 version there?
- Kellog
I have my 5.13 upgrade sitting here ready and I'm eager. But I'm also deep into 2 projects. If there are any problems w/4.61 pre-existing files, will there still be my older version of DP there to work with? Thanks, Kelly
Mac mini (2018) 3.2 Ghz 6 Core Intel Core i7 w/64 GB ram, OSX Catalina 10.15.7, DP 10.13, UAD Apollo Quad, Komplete 13 Ultimate, Superior Drummer 3, EZ Keys, EZ Bass, EZ Mix 2, Stylus RMX 1.7f, Avid Eleven Rack.
- doodles
4.61 will stay there, it'll just install 5.13 separately. HOWEVER be aware that once you've saved a file in dp 5.13, it won't be backwards compatible. it's got a totally different file system going on, so if you want to then work on it in an earlier version, you'll need to do a "save as" including duplicate audio.
I'd be careful with something else: the MAS plugins will be updated to the new 5.x version, and if you need to launch DP 4.6x they may have problems or not work at all... ?
If I were you, I'd backup your current MAS plugins, located in /Library/Audio/Plug-Ins/MAS before installing 5.x, just in case...
- Kellog
Many thanks Doodles and 96khz for the info. This forum is such an education and a safety tether for me, Kelly
