Zjcc56 wrote:So after spending some time with apple/motu i just got referred back to motu by the pro applications department saying it was a driver problem...
call motu, be at your computer when you call.
Listen to what they say and do exactly what they tell you while they are on the phone. They will help you.
I have tried many things up date os X update drivers over and over changed firewire cables unplugged it and switched the voltage back and forth to do a factory reset... nothing
do you see the motu device (or any device?) listed in system profiler under firewire? option-click apple menu, system profiler is first menu item...click "firewire" on the left side.
open motu audio setup in your applications folder. what is the driver version listed at the bottom of the window?
mac pro 3.2 8-core, osx 10.6.1, 10gb, 2x500gb
cubase 5.1, reason 4, ni komplete 6
motu 24 i/o, motu mtp av + mtp I, hr824 + hrs120, srh840, big knob
access virus indigo, roland d-50, korg microkontrol
e-mu proteus/1, e-mu xl-1 turbo, korg m1r, korg ms2000r, kurzweil 1000px, roland d-110, roland jv-2080, yamaha tx-81z
Manufacturer: 0x1F2
Model: 0x102800
GUID: 0x1F2000001C01A
Maximum Speed: Up to 400 Mb/sec
Connection Speed: Up to 400 Mb/sec
Sub-units:
Unknown Unit:
Unit Software Version: 0x5
Unit Spec ID: 0x1F2
i dont really under stand what it says unknown unit....i think thats kinda weird but im not a programmer.....
and the external hd thing...i have to do that when i have some time
my working motu 828mkii says "unknown unit" too - it's not an indication of a problem. you appear to have the correct drivers installed as well.
when you installed the drivers...you didn't change the install location, correct? make sure you leave it as default - don't click the "change location..." button.
