DP 5.13 won't launch in Leopard
Upon launch, I get message, "Digital Performer is unable to run because the MIDI system has crashed. Please quit any programs that are using MIDI and try again." DP will not run at all.
There are no other programs running, and this is a standalone system with no interfaces attached.
Macbook Pro 2.33 gHz Intel Core 2 Duo / 2GB RAM / OS X 10.5.1
- Eleventh Hour Sound
I'm able to run it an a MacBook Pro....
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars
Yes, I've been able to run it in both on my MacBook Pro. If I open a huge file with a lot of plug ins it might crash, but otherwise it seems to work.
- csiaudio
- Location: Indiana; Where the corn is tall and the women are wide!
Capturing the Colors of Sound!
Mac Mini M1 2020 -- DP 11.2 -- Universal Audio Apollo Quad -- Apollo Twin -- SPL Kultube Compressor -- Slate Virtual Mic -- Eve SC207's w/KRK Sub
Re: DP 5.13 won't launch in Leopard
HAve you downloaded the MIDI update from MOTU...?
["MIDI Life Crisis"]HAve you downloaded the MIDI update from MOTU...?[/quote]
Yup! To no avail....
- Mr_Clifford
It's not DP, it's your Audio/MIDI setup which is crashing. You need to check your Library/Audio/MIDI Drivers folder to see if any MIDI drivers have been installed there. If so, try removing them all and putting them back one by one to find the culprit. You don't need to launch DP to test this, just launch the AMS (Audio/MIDI Setup) and it will tell you that it's crashed.magnetman wrote:Upon launch, I get message, "Digital Performer is unable to run because the MIDI system has crashed. Please quit any programs that are using MIDI and try again." DP will not run at all.
DP needs this utility to be functional in order to operate properly. Even if you're not using MIDI.
You are absolutely correct, sir! Thank you for your accurate help in resolving this- greatly appreciated!
best,
Mike Stern
best,
Mike Stern
Mr_Clifford wrote:It's not DP, it's your Audio/MIDI setup which is crashing. You need to check your Library/Audio/MIDI Drivers folder to see if any MIDI drivers have been installed there. If so, try removing them all and putting them back one by one to find the culprit. You don't need to launch DP to test this, just launch the AMS (Audio/MIDI Setup) and it will tell you that it's crashed.magnetman wrote:Upon launch, I get message, "Digital Performer is unable to run because the MIDI system has crashed. Please quit any programs that are using MIDI and try again." DP will not run at all.
- Shooshie
Good call Mr_Clifford!
Shoosh
Shoosh
