Basic question - Send vs. Insert
PaganGods
Post by PaganGods »
I need to conserve computing resources - my current project is nearing 100 % CPU capacity. I want to take about 10 inserts that are all using Camelspace and convert them to 1 effect bus with 10 sends. The problem is that some of the tracks are supposed to be 100 % wet so I zeroed the gain on the audio track, but now they aren't sending signal to Aux. Is there a way to send the signal to Aux even though the audio track gain is turned all the way down? thanks. (confused, but trying to learn).
Rainman
Post by Rainman »
set your sends to pre-fader, the button is located next to the "m" on the strip, I believe it's a "p" (not at DAW right now.
DP 10.0, UA Apollo Two, UA Octo, far too many plugs.
aaronlyon
Post by aaronlyon »
Next to the Send volume knob, see the little M and P buttons? M is for mute, and P is the "Pre/Post Fader Toggle." You want to send pre fader. Then you can drop the track's fader down to -infinity, and the Send will still work.
-a
DP7*, Mac Pro Quad 2.66GHz, 12GB RAM, MOTU 828mk3, Mac OS 10.6*
* Bleeding edge updater--if it's released, I've updated, and bled.
PaganGods
Post by PaganGods »
Thanks....that is so much easier than I expected. And it's working like a charm.
